Home » Archived » Test and Performance Tools Platform (TPTP) » Generating models using EMF
Generating models using EMF [message #5824] Wed, 16 February 2005 01:31 Go to next message
I have been attempting to regenerate the hyades data models with minor
adjustments using the hierarchy.genmodel under
org.eclipse.hyades.models.hierarchy/src-hmodel/model.
When I attempt to open this file, I get the following error:
Problems encountered in the model
Unable to resolve proxy
'platform:/resource/org.eclipse.emf.ecore/src/model/Ecore.ec ore#//EObject'
Its use is by
'platform:/resource/library/src/model/hierarchy.ecore#//Corr elationEntry/val
ue'
Its use is by
ue'
'platform:/resource/org.eclipse.emf.ecore/src/model/Ecore.ec ore#//EStructura
lFeature'
Its use is by
'platform:/resource/library/src/model/hierarchy.ecore#//exte nsions/LeftOpera
nd/feature'
Its use is by
nd/feature'
But the file still opens. I tried adding a few EClasses using
'hierarchy.ecore' and regenerated the data model using the above mentioned
file. The new EClasses are generated fine but the HierarchyPackage and the
HierarchyFactory is not updated accordingly.
Any help will greatly be appreciated.
Re: Generating models using EMF [message #5954 is a reply to message #5824] Thu, 17 February 2005 10:31 Go to previous message
Hi Nima,
The easiest way to regen the Hyades data models is to checkout/import all
the models plugins (org.eclipse.hyades.models.*) and org.eclipse.emf.ecore
plugin, make sure that all the source folders are named "src" and not
"src-*" (you'll need to rename them if you import the plugins).
If you use Rose to view/modify the models then you need to set the
HYADES_MODELS_PATH path variable to point to the Eclipse workspace folder
where you have the models/EMF projects, then open
WORKSPACE_PATH/org.eclipse.hyades.models.hierachy/src/rose/h yades-models.mdl
file. Before you reload then genmodel you need to refresh all models
projects in the workspace to make sure you captured all the changes done
externally in Rose.
Marius
"Nima M." <microbold@hotmail.com> wrote in message
news:cuueer$bdk$1@www.eclipse.org...
> Its use is by
> ue'
> Its use is by
> ue'
> lFeature'
> Its use is by
> nd/feature'
> Its use is by
> nd/feature'
the
Previous Topic:Log and Trace Analyzer sample- setUserInput never called
Next Topic:Non-Java System Under Test and Hyades
Current Time: Mon Jul 21 20:05:36 EDT 2025
Powered by FUDForum. Page generated in 0.03339 seconds
