how to compare pointcuts [message #65056] |
Mon, 22 May 2006 05:31  |
Hi!
Wondering if there is a way to compare to different pointcuts using AJDT.
I am not looking for a graphical compare such as the crosscutting
comparison,
rather a compare such as the cross reference comparison.
Since I am a AspectJ/AJDT newbie what am I asking for might already exist in
AJDT but I can't find it.
If it does not exist, is it because it is not possible? Is an advice needed
perhaps?
Jimisola
Re: how to compare pointcuts [message #65170 is a reply to message #65148] |
Tue, 23 May 2006 12:48   |
Hi!
Thanks for the reply.
Well, cross references view worked like that I expected then.
However, even if it is more useful to show the matches (or potential
matches) against the advice rather than the pointcut I don't see why one
shouldn't be able to compare pointcuts if it is doable since it saves me as
a developer time. It's not mutual exclusive,so why don't have the best of
both worlds?
Jimisola
"Matt Chapman" <mpchapman@gmail.com> wrote in message
news:e4vdkl$u2j$1@utils.eclipse.org...
> Jimisola Laursen wrote:
>> Hi!
>> AJDT.
>> comparison,
>> in AJDT but I can't find it.
>> needed perhaps?
> Hi Jimisola,
> Yes, simply write some empty advice using the pointcut, and then you can
> use the cross references view to see the matches.
> A pointcut doesn't do anything on its own, advice is needed to have an
> effect, so therefore it is more useful to show the matches (or potential
> matches in the case of runtime tests) against the advice rather than the
> pointcuts.
> Matt.
Re: how to compare pointcuts [message #65276 is a reply to message #65192] |
Wed, 24 May 2006 08:04  |
news:e4viv5$617$1@utils.eclipse.org...
>> as a developer time. It's not mutual exclusive,so why don't have the best
>> of both worlds?
> We're all for saving developers' time - it's just a matter of doing it in
> such a way so as to not confuse or mislead other developers. How about if
> you could select two pointcuts in the outline view or package explorer and
> compare them with the crosscutting comparison view?
That would be very nice. Actually, just the behaviour/functionality that I
expected.
I believe that this is the same way that one compares advices
(http://www.eclipse.org/ajdt/newfeatures/ "Additional Crosscutting
Comparison functionality ") - correct?
> There has been discussion about having a separate "pointcut matcher" tool
> to assist with writing pointcuts - see enhancement 109759 in bugzilla.
Looks as if it would be a great helper when writing point cuts.
Jimisola
Re: how to compare pointcuts [message #593807 is a reply to message #65056] |
Tue, 23 May 2006 12:35  |
> Hi!
> comparison,
> perhaps?
Hi Jimisola,
pointcuts.
Matt.
Re: how to compare pointcuts [message #593816 is a reply to message #65148] |
Hi!
both worlds?
Jimisola
>> Hi!
>> AJDT.
>> comparison,
>> needed perhaps?
> Hi Jimisola,
> pointcuts.
> Matt.
Re: how to compare pointcuts [message #593825 is a reply to message #65170] |
Tue, 23 May 2006 14:06  |
> both worlds?
in such a way so as to not confuse or mislead other developers. How
about if you could select two pointcuts in the outline view or package
explorer and compare them with the crosscutting comparison view?
tool to assist with writing pointcuts - see enhancement 109759 in bugzilla.
Matt.
Re: how to compare pointcuts [message #593861 is a reply to message #65192] |
>> of both worlds?
expected.
Jimisola
FUDForum. Page generated in 0.83065 seconds
