Home » Eclipse Projects » Mylyn » "Open with web browser" doesn't work
"Open with web browser" doesn't work [message #65053] Fri, 06 February 2009 15:46 Go to next message
Hello!
I use Mylyn 3.0.4 with MyEclipse 7.0 against a JIRA repository. I think
ever since MyEclipse 7.0, the "Open with Web Browser" button on the JIRA
bug in Eclipse doesn't work anymore - nothing happens when I press it (the
button has a "pressed animation", though).
I have Eclipse configured to use the internal web browser. But even when
I open both the internal web browser and the MyEclipse browser, the bug
still doesn't show up in either of the two.
Re: "Open with web browser" doesn't work [message #65084 is a reply to message #65053] Fri, 06 February 2009 16:07 Go to previous messageGo to next message
> (the button has a "pressed animation", though).
> when I open both the internal web browser and the MyEclipse browser, the
> bug still doesn't show up in either of the two.
Hello Karsten,
is it possible to open the Eclipse help system and a normal web browser on a HTML page in your
workspace?
Which operating system your are using? On Linux, you have to install the correct libraries to enable
the internal web browser, package "libxul0d" on Ubuntu.
Cheers, Jörg
Re: "Open with web browser" doesn't work [message #65103 is a reply to message #65084] Sat, 07 February 2009 15:52 Go to previous messageGo to next message
HTML page in your
> workspace?
Yes, everything else works - check out this screencast I did:
http://screencast.com/t/AJ0lqaDE3vP
XP Pro SP 3.
Karsten
Re: "Open with web browser" doesn't work [message #65171 is a reply to message #65103] Thu, 12 February 2009 10:03 Go to previous message
I posted a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264697
Re: "Open with web browser" doesn't work [message #596100 is a reply to message #65053] Fri, 06 February 2009 16:07 Go to previous message
Hello Karsten,
workspace?
Cheers, Jörg
Re: "Open with web browser" doesn't work [message #596113 is a reply to message #65084] Sat, 07 February 2009 15:52 Go to previous message
HTML page in your
> workspace?
XP Pro SP 3.
Karsten
Re: "Open with web browser" doesn't work [message #596137 is a reply to message #65103] Thu, 12 February 2009 10:03 Go to previous message
Previous Topic:WikiText and Bugzilla
Next Topic:Generic Web Connector - Site Authentification for "Open Task" and long char-ids
Current Time: Sun Jul 13 16:14:55 EDT 2025
Powered by FUDForum. Page generated in 0.63019 seconds
