Home » Language IDEs » ServerTools (WTP) » SSL problem with tomcat 5.5
SSL problem with tomcat 5.5 [message #65024] Wed, 12 January 2005 10:30 Go to next message
Originally posted by: mynewsgroup.web.de
I've got Tomcat 5.5 working with SSL on port 8443 when starting it as a
windows serice. But when I start Tomcat with the WTP (1.0 M2) I cannot get
any connection to 8443. There is no startup message for that port.
When opening the server in the "Servers" view, there are only the ports
8005, 8080 and 8009 listed. Does this server definition use a different
server.xml than the one in <tomcat-home>/conf?
Sebastian
Re: SSL problem with tomcat 5.5 [message #65031 is a reply to message #65024] Wed, 12 January 2005 12:23 Go to previous messageGo to next message
Originally posted by: james.kilbride.gd-ais.com
YEP! It took me a while to realize that but it seems to make a copy of the
file out of tomcat-home when you create the new server type, so any
changes you make to the server configuration after creating the type
doesn't seem to propagate across. Especially when you create the server in
the servers view. Try deleting the server and type and then create a new
one.
Sebastian Scheid wrote:
> Regards
> Sebastian
Re: SSL problem with tomcat 5.5 [message #65041 is a reply to message #65031] Wed, 12 January 2005 12:52 Go to previous messageGo to next message
"James Kilbride" <james.kilbride@gd-ais.com> schrieb im Newsbeitrag
news:cs3meq$9u5$1@www.eclipse.org...
> one.
Thanks for the quick reply. I will try that.
Sebbo
Re: SSL problem with tomcat 5.5 [message #65051 is a reply to message #65041] Wed, 12 January 2005 12:58 Go to previous messageGo to next message
"Sebastian Scheid" <mynewsgroup@web.de> schrieb im Newsbeitrag
news:cs3o5l$g9a$1@www.eclipse.org...
>> the file out of tomcat-home when you create the new server type, so any
>> in the servers view. Try deleting the server and type and then create a
>> new one.
It works! I deleted the server and created a new one (with port 8443 defined
in tomcat-home's server.xml).
Sebastian
Re: SSL problem with tomcat 5.5 [message #65076 is a reply to message #65051] Wed, 12 January 2005 16:47 Go to previous messageGo to next message
Now if only somebody would write up a workaround for the JNDI resources
issue when the created server doesn't read the context files, because it
seems to be adding a context into the server.xml.
>>> new one.
> Regards
> Sebastian
Re: SSL problem with tomcat 5.5 [message #65291 is a reply to message #65076] Thu, 13 January 2005 04:00 Go to previous message
news:cs45tf$659$1@www.eclipse.org...
I have a common DataSource defined in conf/context.xml and it works.
Sebastian
Previous Topic:Cant open a .tag file with JSP or HTML editor.
Next Topic:Unable to have XML code completion wit M2
Current Time: Fri Jul 18 01:34:58 EDT 2025
Powered by FUDForum. Page generated in 0.48648 seconds
