Home » Eclipse Projects » GEF » Drag and Drop in GEF
Drag and Drop in GEF [message #65011] |
Mon, 17 February 2003 12:11  |
Support I have 2 container figures (e.g. Circuit in Logic Editor), and one
of them has an AndGate Figure.
Can I add Drag and Drop functionality to the Circuit so that I can drag an
AndGate Figure from 1 circuit and drop it to a new Circuit , so that at the
end both Ciruit has an AndGate and the original AndGate Figure never moves
its location?
Thanks for any help.
Re: Drag and Drop in GEF [message #65586 is a reply to message #65185] |
Wed, 19 February 2003 01:44   |
Originally posted by: sy_cheung2.yahoo.com
I can't find handleKeyPressed(...), handleKeyReleased(...) in the
DragEditPartsTracker to overload.
I try overloading
handleKeyDown(KeyEvent e)
handleKeyUp(KeyEvent e),
And I put breakpoints in handleKeyDown() and handleKeyUp(), they won't
break until I I start drag and then press a Key.
this is not what we want. Right? We want to identify if a Ctrl key was press
when we start drag NOT when we drag if a Ctrl Key is press.
Am I missing something? Please provide further advice.
Thanks for your help.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b2rete$fdr$1@rogue.oti.com...
> The correct way to do this (if i understand you) is to hold the CTRL key
> while dragging. There is no reason to use native drag and drop to copy
> something within the same viewer. Instead, make a subclass of
> DragEditPartsTracker that changes the Request somehow whenever CTRL is
> pressed in released.
> override handleKeyPressed(...), handleKeyReleased(...) to update the
cursor
> (cursor is either normal drag cursor or SharedCursors.CURSOR_TREE_ADD).
You
> could also store whether CTRL is pressed or not, but you can query this
from
> Display at any time.
> in updateTargetRequest(), indicate whether the drag is a "copy" or a
"move".
> Finally, submit this code to GEF so we can release it :-)
> "yinglcs" <yinglcs@netscape.com> wrote in message
> news:b2r3j1$6ld$1@rogue.oti.com...
one
an
> the
moves
> > its location?
Re: Drag and Drop in GEF [message #65671 is a reply to message #65586] |
Wed, 19 February 2003 10:34   |
> I try overloading
correct, the drag tracker is loaded when you press the mouse.
press
You can detect if the Control key is down (in the cases where control key
pressed comes before the DragTracker is even created) several way, the
easiest would be:
The drag tracker does receive the initial mouseDown event. So in
handleMouseDown(int) call
getCurrentInput().isControlKeyPressed().
> cursor
> You
> from
> "move".
> one
drag
> an
> > the
> moves
> > > its location?
Re: Drag and Drop in GEF [message #65881 is a reply to message #65671] |
Thu, 20 February 2003 12:03   |
I able to create MyDragEditPartsTracker instead of DragEditPartsTracker when
a Ctrl during Dragging.
And I change teh cursor to TREE_ADD and change the ChangeBoundsRequest to
be type REQ_ADD (instead of REQ_MOVE),
But when I drag it, the cursor DOES NOT change, it still end up a MOVE
command. I can tell that because the Label become gray and with dotted lines
(the way it appears when I move it).
Could you please tell me what do I miss?
Thanks.
public class MyDragEditPartsTracker extends DragEditPartsTracker {
protected boolean handleDragStarted() {
System.out.println("drag");
setCursor(SharedCursors.CURSOR_TREE_ADD); /// <----------------
return super.handleDragStarted();
protected void updateTargetRequest() {
ChangeBoundsRequest request = (ChangeBoundsRequest) getTargetRequest();
request.setEditParts(getOperationSet());
Dimension d = getDragMoveDelta();
request.setMoveDelta(new Point(d.width, d.height));
request.setLocation(getLocation());
request.setType(REQ_ADD); /// this is REQ_ADD
news:b306j5$s90$1@rogue.oti.com...
> > I try overloading
won't
> press
> easiest would be:
key
copy
> > cursor
> > You
this
> > from
> > "move".
and
> > one
> drag
> > an
> at
> > > the
> > moves
> > > > its location?
Re: Drag and Drop in GEF [message #65935 is a reply to message #65881] |
Thu, 20 February 2003 19:15  |
ADD is a special type of MOVE, which is why you are seeing the same
feedback. You need to invent a new ID that doesn't exist yet.
A MOVE is within a single parent. An ADD is what happens when you MOVE
across parents. This is actually treated as an ORPHAN with the old parent,
and an ADD to the new parent.
news:b3304l$2mg$1@rogue.oti.com...
when
lines
> Thanks.
> > > I try overloading
> won't
> > press
key
> > easiest would be:
> key
> copy
is
> > > cursor
> > > You
> this
> > > from
> > > "move".
> and
> > > one
> > drag
> > > an
that
> > at
> > > > the
never
> > > moves
> > > > > its location?
Current Time: Mon Sep 01 06:08:52 EDT 2025
Powered by FUDForum. Page generated in 0.04886 seconds
