Home » Eclipse Projects » GEF » initial layout & createFigure()
initial layout & createFigure() [message #65006] Mon, 17 February 2003 12:06 Go to next message
My GEF Editor reads an xml file and attempts to represent it with
figures. Since node locations are not stored in the xml file, I need to
write code to handle an initial layout--otherwise all of the nodes just
stack up ontop of each other.
I attempted to use a class variable in my NodeEditPart to keep track of
instances so that I could stagger the display of newly created nodes.
protected IFigure createFigure() {
NodeFigure nf = new NodeFigure();
Point location = new Point(instanceNumber * 200 + 10, 20);
nf.setLocation(location);
Object obj = getModel();
if(obj instanceof Controller){
Controller c = (Controller) obj;
nf.setText(c.displayName());
return nf;
This proved to be a very bad idea :). What is the right way to handle this?
John-Mason Shackelford
Software Developer
Pearson Educational Measurement - eMeasurement Group
2510 North Dodge St.
Iowa City, IA 52245
ph. 319-354-9200x6214
john-mason.shackelford@pearson.com
http://etest.ncspearson.com
Re: initial layout & createFigure() [message #65072 is a reply to message #65006] Mon, 17 February 2003 13:29 Go to previous message
<user@domain.invalid> wrote in message
news:3E5116AA.3080202@domain.invalid...
Can you detect the presence of an "un-annotated" (See you next post) model
and perform an initial intelligent layout? Probably try to do whatever the
user would do manually.
> return nf;
this?
You should be using an XYLayout. One way to handle this would be in the
code in the child EditPart that sets the constraint in the XYLayout
associated with the child. If the child *model* has no stored constraint,
then generate one based on the child's index in the parent. Such as new
Rectangle (index*avgWidth, 20, avgWidth, avgHeight).
> Software Developer
> Iowa City, IA 52245
Previous Topic:Need help fixing "class must implement abstract method" error !!
Next Topic:Difference between version 2.02 and 2.1
Current Time: Sat Jul 26 14:02:03 EDT 2025
Powered by FUDForum. Page generated in 0.06152 seconds
