Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo - Performance penalty for larger models in HibernateResource
teneo - Performance penalty for larger models in HibernateResource [message #64995] Tue, 19 December 2006 18:14 Go to next message
Hi Martin,
I'm trying to load a large model into a tree based editor (using a
HibernateResource). I got the impression that the performance drop
over-proportionally with the model size.
The tree that shows up consists of the following hierarchy:
children per node: 1->580->120
total #objects per hierarchy level: 1->580->70,000
I am having problems already when the tree expands down to level 1 (the 580),
that is because the editor must determine number of children in order to decide
whether or not display the expansion icon or not.
While I was waiting for my tree to be displayed I monitored java and the running
mysql and figured, that the DB was mostly idle but java was on full load for
several minutes.
I have run the profiler and found that these two stack frames count for roughly
about 35% of the CPU:
TRACE 301131:
java.util.ArrayList.indexOf(ArrayList.java:219)
java.util.ArrayList.contains(ArrayList.java:201)
org.eclipse.emf.teneo.resource.StoreResource.attachedHelper( StoreResource.java:444)
org.eclipse.emf.teneo.resource.StoreResource.attached(StoreR esource.java:421)
TRACE 301145:
java.util.ArrayList.indexOf(ArrayList.java:220)
CPU SAMPLES BEGIN (total = 101885) Tue Dec 19 23:43:27 2006
rank self accum count trace method
1 49.85% 49.85% 50789 300545 java.net.PlainSocketImpl.socketAccept
2 19.36% 69.21% 19728 301131 java.util.ArrayList.indexOf
3 16.07% 85.29% 16377 301145 java.util.ArrayList.indexOf
4 4.91% 90.20% 5004 301047 org.eclipse.swt.internal.win32.OS.WaitMessage
Both stack frames stem from the same line of code in StoreResource:
StoreResource.java:444:
if (newEObjects.contains(eObject) || loadedEObjects.contains(eObject))
I know that the checks are necessary but may be the ArrayLists can be replaced
by some hash based collection or additionally index for this existence check?
Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #65060 is a reply to message #64995] Tue, 19 December 2006 18:25 Go to previous messageGo to next message
I can just answer myself:
I have just changed these two collection to HashSet and performance improved as
expected (load case):
CPU SAMPLES BEGIN (total = 16553) Wed Dec 20 00:19:58 2006
1 49.29% 49.29% 8159 300547 java.net.PlainSocketImpl.socketAccept
2 13.76% 63.05% 2278 301076 org.eclipse.swt.internal.win32.OS.WaitMessage
3 5.65% 68.71% 936 301206
org.hibernate.engine.StatefulPersistenceContext.afterTransac tionCompletion
4 4.30% 73.01% 712 301222
5 3.46% 76.47% 573 300743 java.net.SocketInputStream.socketRead0
The StoreResource existence check does not count any more. Load and display time
is now acceptable.
Looks good except that I don't know how much your code does rely on the
insertion order of the elements? If not then you might consider this change.
Andre
Andre Pareis wrote:
> Hi Martin,
> 580), that is because the editor must determine number of children in
> order to decide whether or not display the expansion icon or not.
> running mysql and figured, that the DB was mostly idle but java was on
> full load for several minutes.
> roughly about 35% of the CPU:
> TRACE 301131:
> TRACE 301145:
> replaced by some hash based collection or additionally index for this
> existence check?
> Regards
> Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #65154 is a reply to message #65060] Wed, 20 December 2006 04:40 Go to previous messageGo to next message
Hi Andre,
I have changed this to hashset and checked it in. If you are on cvs can you check it?
gr. Martin
> improved as expected (load case):
> display time is now acceptable.
> change.
> Thanks
> Andre
> Andre Pareis wrote:
>> Hi Martin,
>> (the 580), that is because the editor must determine number of
>> children in order to decide whether or not display the expansion icon
>> or not.
>> the running mysql and figured, that the DB was mostly idle but java
>> was on full load for several minutes.
>> for roughly about 35% of the CPU:
>> TRACE 301131:
>> TRACE 301145:
>> existence check?
>> Regards
>> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - Performance penalty for larger models in HibernateResource [message #65238 is a reply to message #65154] Wed, 20 December 2006 19:39 Go to previous messageGo to next message
Hi Martin,
I was unable to test this today time-wise but I will do it this week and get
back to you as soon as possible.
But let me thank you in advance for this quick implementation :)
Andre
Martin Taal wrote:
> Hi Andre,
> you check it?
> gr. Martin
>> the insertion order of the elements? If not then you might consider
>> this change.
>> Thanks
>> Andre
>> Andre Pareis wrote:
>>> Hi Martin,
>>> or not.
>>> TRACE 301131:
>>> TRACE 301145:
>>> existence check?
>>> Regards
>>> Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #65427 is a reply to message #65238] Thu, 21 December 2006 18:36 Go to previous messageGo to next message
Hi Martin,
I've tested for a few hours now without any problems. I would like to add that I
have only classes which do not override hashCode or equals. Also I don't do
unit testing, I did only a few load/modify/save cycles.
I'm still fighting against performance problems during save, which might have to
do with the save-update cascades which might cascade too deep. I have ~160000
objects in the loadedEObjects set which might be the cause. Maybe I have to
remove some of the to-one associations which as I understand can not be lazily
loaded by hibernate...
Andre
Andre Pareis wrote:
> Hi Martin,
> get back to you as soon as possible.
> Regards
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> can you check it?
>> gr. Martin
>>> this change.
>>> Thanks
>>> Andre
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> icon or not.
>>>> TRACE 301131:
>>>> TRACE 301145:
>>>> be replaced by some hash based collection or additionally index for
>>>> Regards
>>>> Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #65512 is a reply to message #65427] Fri, 22 December 2006 15:45 Go to previous message
Hi Andre,
Does it load 160000 objects because of the one-to-one relations?
Another question is if hibernate actually saves all 160000 objects even if many of them did not
change. Does it do that?
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> add that I have only classes which do not override hashCode or equals.
> Also I don't do unit testing, I did only a few load/modify/save cycles.
> have to do with the save-update cascades which might cascade too deep. I
> have ~160000 objects in the loadedEObjects set which might be the cause.
> Maybe I have to remove some of the to-one associations which as I
> understand can not be lazily loaded by hibernate...
> Thanks
> Andre
> Andre Pareis wrote:
>> Hi Martin,
>> and get back to you as soon as possible.
>> Regards
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> can you check it?
>>> gr. Martin
>>>> this change.
>>>> Thanks
>>>> Andre
>>>> Andre Pareis wrote:
>>>>> Hi Martin,
>>>>> icon or not.
>>>>> and the running mysql and figured, that the DB was mostly idle but
>>>>> java was on full load for several minutes.
>>>>> TRACE 301131:
>>>>> TRACE 301145:
>>>>> Regards
>>>>> Andre
The Netherlands
Re: teneo - Performance penalty for larger models in HibernateResource [message #597166 is a reply to message #64995] Tue, 19 December 2006 18:25 Go to previous message
is now acceptable.
Andre
Andre Pareis wrote:
> Hi Martin,
> TRACE 301131:
> TRACE 301145:
> existence check?
> Regards
> Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #597203 is a reply to message #65060] Wed, 20 December 2006 04:40 Go to previous message
Hi Andre,
gr. Martin
> change.
> Thanks
> Andre
> Andre Pareis wrote:
>> Hi Martin,
>> or not.
>> TRACE 301131:
>> TRACE 301145:
>> existence check?
>> Regards
>> Andre
The Netherlands
Re: teneo - Performance penalty for larger models in HibernateResource [message #597253 is a reply to message #65154] Wed, 20 December 2006 19:39 Go to previous message
Hi Martin,
Andre
Martin Taal wrote:
> Hi Andre,
> you check it?
> gr. Martin
>> this change.
>> Thanks
>> Andre
>> Andre Pareis wrote:
>>> Hi Martin,
>>> or not.
>>> TRACE 301131:
>>> TRACE 301145:
>>> existence check?
>>> Regards
>>> Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #600191 is a reply to message #65238] Thu, 21 December 2006 18:36 Go to previous message
Hi Martin,
Andre
Andre Pareis wrote:
> Hi Martin,
> Regards
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> can you check it?
>> gr. Martin
>>> this change.
>>> Thanks
>>> Andre
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> icon or not.
>>>> TRACE 301131:
>>>> TRACE 301145:
>>>> Regards
>>>> Andre
Re: teneo - Performance penalty for larger models in HibernateResource [message #600222 is a reply to message #65427] Fri, 22 December 2006 15:45 Go to previous message
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Thanks
> Andre
> Andre Pareis wrote:
>> Hi Martin,
>> Regards
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> can you check it?
>>> gr. Martin
>>>> this change.
>>>> Thanks
>>>> Andre
>>>> Andre Pareis wrote:
>>>>> Hi Martin,
>>>>> icon or not.
>>>>> TRACE 301131:
>>>>> TRACE 301145:
>>>>> Regards
>>>>> Andre
The Netherlands
Previous Topic:[Teneo] Setting Id generator from ecore file
Next Topic:How to programmatically generate editor code from .ecore file
Current Time: Wed Jul 30 17:08:20 EDT 2025
Powered by FUDForum. Page generated in 0.06156 seconds
