Home » Modeling » EMF » [Teneo/CDO] IllegalArgumentException: EClass * does not have an entity name, has it been mapped to H
[Teneo/CDO] IllegalArgumentException: EClass * does not have an entity name, has it been mapped to H [message #646894] |
Sun, 02 January 2011 17:28 |
Dear Martin / Eike,
I'm puzzled by the following exception, it seems CDO has correctly processed
the entity/class "Refill", but Teneo/Hibernate says does not have entity
name / not mapped ?
Please help. Thank you.
00:12:48.396 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Reading
revision: ID=oid8, className=Refill, version=0,
branchPoint=BranchPoint[Branch[id=0, name=MAIN], *], revised=0,
resource=NULL, container=oid2, featureID=-1
00:12:48.397 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Read
feature created: 26/12/10 0:00
feature lastModified: 29/12/10 0:00
feature destNumber: 08571234567
feature voucherCode: I50
feature price: 51.500
feature cost: 49.900
00:12:48.398 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Read
feature dealerDate: 25/12/10 0:00
feature status: 1
00:12:48.398 [Thread-5] WARN o.e.e.c.i.c.p.CDODataInputImpl - Reading CDOID
of type 5 (TEMP_OBJECT)
feature dealer: oid2
00:12:48.398 [Thread-5] WARN o.e.e.c.s.i.n.p.CommitTransactionIndication -
Reading 1 dirty object deltas
00:12:48.399 [Thread-5] WARN o.e.e.c.i.c.p.CDODataInputImpl - Reading
CDOIDObject of sub type 2 (LONG_WITH_CLASSIFIER)
00:12:48.399 [Thread-5] WARN o.e.e.c.i.c.p.CDODataInputImpl - Reading CDOID
00:12:48.399 [Thread-5] WARN o.e.internal.net4j.buffer.BufferPool -
Retaining Buffer@29[RELEASED]
00:12:48.402 [Thread-5] WARN o.e.n.u.o.m.ProgressDistributor -
Distribution: 50.0%, 50.0%, (indicatingCommitDistributor: test)
00:12:48.403 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
version for Refill@oid7:0v0: v1
branchPoint Refill@oid7:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Refill@oid7:0v1: *
00:12:48.404 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
version for Refill@oid6:0v0: v1
branchPoint Refill@oid6:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Refill@oid6:0v1: *
version for Refill@oid5:0v0: v1
00:12:48.405 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
branchPoint Refill@oid5:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Refill@oid5:0v1: *
version for Refill@oid4:0v0: v1
branchPoint Refill@oid4:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Refill@oid4:0v1: *
version for Refill@oid3:0v0: v1
00:12:48.406 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
branchPoint Refill@oid3:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Refill@oid3:0v1: *
version for Dealer@oid2:0v0: v1
branchPoint Dealer@oid2:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Dealer@oid2:0v1: *
00:12:48.407 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
version for CDOResource@oid1:0v0: v1
branchPoint CDOResource@oid1:0v1: BranchPoint[Branch[id=0, name=MAIN], 03
Jan 11 00:12:48:403]
revised CDOResource@oid1:0v1: *
version for Refill@oid8:0v0: v1
00:12:48.408 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
branchPoint Refill@oid8:0v1: BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11
00:12:48:403]
revised Refill@oid8:0v1: *
00:12:48.409 [Thread-5] WARN o.e.e.c.s.c.revision.BaseCDORevision - Setting
version for
CDOResource@OID:http://www.eclipse.org/emf/CDO/Eresource/2.0 .0#CDOResource#1:0v1:
v2
branchPoint
CDOResource@OID:http://www.eclipse.org/emf/CDO/Eresource/2.0 .0#CDOResource#1:0v2:
BranchPoint[Branch[id=0, name=MAIN], 03 Jan 11 00:12:48:403]
revised
00:12:48.410 [Thread-5] WARN o.e.e.c.s.i.h.HibernateThreadContext - Setting
commitcontext in threadlocal
00:12:48.410 [Thread-5] WARN o.e.e.c.s.i.h.HibernateStoreAccessor -
Creating hibernate session and transaction
00:12:48.420 [Thread-5] WARN o.e.net4j.util.om.log.Logger@4936f3 - EClass
Refill does not have an entity name, has it been mapped to Hibernate?
java.lang.IllegalArgumentException: EClass Refill does not have an entity
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore .getEntityName(HibernateStore.java:184)
~[bin/:na]
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Accessor.write(HibernateStoreAccessor.java:609)
~[bin/:na]
org.eclipse.emf.cdo.internal.server.TransactionCommitContext .write(TransactionCommitContext.java:328)
[org.eclipse.emf.cdo.server_3.0.1.v20100706-1131.jar:na]
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLo op(InternalCommitContext.java:35)
org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLo op(InternalCommitContext.java:1)
org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
[org.eclipse.net4j.util_3.0.1.v20100911-0900.jar:na]
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicatingCommit(CommitTransactionIndicat ion.java:316)
[org.eclipse.emf.cdo.server.net4j_3.0.1.v20100809-1025.jar:n a]
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:168)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:122)
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
[org.eclipse.net4j_3.0.1.v20100809-0342.jar:na]
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:315)
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
[na:1.6.0_22]
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
[na:1.6.0_22]
at java.lang.Thread.run(Thread.java:662) [na:1.6.0_22]
Eclipse Driven Rich Application Development -
http://eclipsedriven.blogspot.com/
Re: [Teneo/CDO] IllegalArgumentException: EClass * does not have an entity name, has it been mapped [message #646913 is a reply to message #646894] |
Mon, 03 January 2011 05:13 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Hendy,
Can you debug into the code where the exception is thrown? There is a entityNameToEClass map which should contain all
eclass to entity name mappings. Can you check what this map contains?
gr. Martin
On 01/02/2011 06:28 PM, Hendy Irawan wrote:
> Dear Martin / Eike,
> name / not mapped ?
> feature status: 1
> 00:12:48:403]
> 00:12:48:403]
> 00:12:48:403]
> 00:12:48:403]
> 00:12:48:403]
> 00:12:48:403]
> 00:12:48:403]
> version for
> v2
> branchPoint
> revised
> at
> ~[bin/:na]
> at
> ~[bin/:na]
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> [na:1.6.0_22]
> at
> [na:1.6.0_22]
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo/CDO] IllegalArgumentException: EClass * does not have an entity name, has it been mapped [message #646920 is a reply to message #646913] |
Mon, 03 January 2011 07:11 |
Thanks Martin.
It contains 16 elements, of which 3 is occupied by CDOResource and CDO
entities, the rest is null. None of my entities/classes are there.
Here is the relevant code. I pretty much copied it from the wiki, and
changing it to use Hibernate instead of CDO-DB. Did I do something wrong
here ?
Thanks ..
protected IStore getStore() {
mapping = TeneoUtil.createMappingProvider();
IHibernateStore store = CDOHibernateUtil.createStore(mapping);
return store;
protected IRepository getRepository(IStore store) {
HashMap<String, String> props = new HashMap<String, String>();
props.put("teneo.mapping.cascade_policy_on_non_containment",
"PERSIST,MERGE");
props.put("teneo.mapping.inheritance", "JOINED");
props.put("teneo.mapping.add_index_for_fk", "true");
props.put("hibernate.hbm2ddl.auto", "update");
props.put("hibernate.connection.pool_size", "10");
props.put("hibernate.cache.provider_class",
"org.hibernate.cache.HashtableCacheProvider");
props.put("hibernate.dialect", "org.hibernate.dialect.HSQLDialect");
props.put("hibernate.connection.driver_class", "org.hsqldb.jdbcDriver");
props.put("hibernate.connection.url", "jdbc:hsqldb:mem:abispulsa");
props.put("hibernate.connection.username", "sa");
props.put("hibernate.connection.password", "");
final IRepository repository =
CDOServerUtil.createRepository(DEFAULT_REPOSITORY_NAME, store, props);
return repository;
protected IManagedContainer getContainer() {
IManagedContainer container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container);
JVMUtil.prepareContainer(container);
CDONet4jUtil.prepareContainer(container);
CDONet4jServerUtil.prepareContainer(container);
container.activate();
return container;
protected CDOSession getSession(IConnector connector) {
CDOSessionConfiguration config = CDONet4jUtil.createSessionConfiguration();
config.setConnector(connector);
config.setRepositoryName(DEFAULT_REPOSITORY_NAME);
return config.openSession();
protected void run() throws CommitException, ParserConfigurationException,
SAXException, IOException, CoreException {
IStore cdoStore = getStore();
IRepository cdoRepository = getRepository(cdoStore);
container = getContainer();
CDOServerUtil.addRepository(container, cdoRepository);
cdoRepository.getPackageRegistry().putEPackage(AbispulsaPack age.eINSTANCE);
// 1. here ?
IAcceptor acceptor = JVMUtil.getAcceptor(container, "default"); //$NON-
NLS-1$
connector = JVMUtil.getConnector(container, "default");
session = getSession(connector);
session.getPackageRegistry().putEPackage(AbispulsaPackage.eI NSTANCE); // 2.
or here??
Martin Taal wrote:
> Hi Hendy,
> entityNameToEClass map which should contain all eclass to entity name
> gr. Martin
>> Dear Martin / Eike,
>> processed the entity/class "Refill", but Teneo/Hibernate says does not
>> have entity name / not mapped ?
>> Reading revision: ID=oid8, className=Refill, version=0,
>> feature status: 1
>> CDOID of type 5 (TEMP_OBJECT)
>> - Reading 1 dirty object deltas
>> Setting version for Refill@oid7:0v0: v1
>> Setting branchPoint Refill@oid7:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Refill@oid7:0v1: *
>> Setting version for Refill@oid6:0v0: v1
>> Setting branchPoint Refill@oid6:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Refill@oid6:0v1: *
>> Setting version for Refill@oid5:0v0: v1
>> Setting branchPoint Refill@oid5:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Refill@oid5:0v1: *
>> Setting version for Refill@oid4:0v0: v1
>> Setting branchPoint Refill@oid4:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Refill@oid4:0v1: *
>> Setting version for Refill@oid3:0v0: v1
>> Setting branchPoint Refill@oid3:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Refill@oid3:0v1: *
>> Setting version for Dealer@oid2:0v0: v1
>> Setting branchPoint Dealer@oid2:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Dealer@oid2:0v1: *
>> Setting version for CDOResource@oid1:0v0: v1
>> Setting branchPoint CDOResource@oid1:0v1: BranchPoint[Branch[id=0,
>> Setting revised CDOResource@oid1:0v1: *
>> Setting version for Refill@oid8:0v0: v1
>> Setting branchPoint Refill@oid8:0v1: BranchPoint[Branch[id=0, name=MAIN],
>> Setting revised Refill@oid8:0v1: *
>> Setting version for
>> v2
>> Setting branchPoint
>> Setting revised
>> Setting commitcontext in threadlocal
>> EClass Refill does not have an entity name, has it been mapped to
>> Hibernate? java.lang.IllegalArgumentException: EClass Refill does not
>> at
>> ~[bin/:na]
>> at
>> ~[bin/:na]
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> [na:1.6.0_22]
>> at
>> [na:1.6.0_22]
Re: [Teneo/CDO] IllegalArgumentException: EClass * does not have an entity name, has it been mapped [message #647026 is a reply to message #646920] |
Tue, 04 January 2011 06:38 |
Hi Hendy,
Yes the package does not seem to be mapped, not sure why though...
Is it possible to package your model/example and send it to me to try it out myself? Or enter it as a bugzilla and
attach you example to it.
Is this CDO 3.0 or 4.0?
gr. Martin
On 01/03/2011 08:11 AM, Hendy Irawan wrote:
> Thanks Martin.
> here ?
> Thanks ..
> return store;
> "PERSIST,MERGE");
> return repository;
> return container;
> // 1. here ?
> NLS-1$
> or here??
> Martin Taal wrote:
>> Hi Hendy,
>> gr. Martin
>>> Dear Martin / Eike,
>>> feature status: 1
>>> Setting version for
>>> v2
>>> Setting branchPoint
>>> Setting revised
>>> at
>>> ~[bin/:na]
>>> at
>>> ~[bin/:na]
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> [na:1.6.0_22]
>>> at
>>> [na:1.6.0_22]
The Netherlands
Current Time: Fri Apr 26 22:14:11 GMT 2024
Powered by FUDForum. Page generated in 0.03311 seconds
