Home » Eclipse Projects » Plugin Development Environment (PDE) » Starting comparison/Opening two files
Starting comparison/Opening two files [message #64969] Wed, 17 June 2009 02:10
Hey All,
I hope somebody could help me with my problem.
I try to compare two files with my GUI. I programmed a plugin opening two
files from the Explorer (GUI). After choosing the files and pressing the
"OK"-Button, the comparing should work and open both compared files as it
will work when you press "Compare with".
But there are many problems. I can't get the name and the location of the
files. The export menu (the drop down menu on the upper-right of EMF
Compare GUI) does not work,and so many buttons on the lower-right don't
work.
For example see the following screenshot:
http://farm4.static.flickr.com/3408/3635057634_7545431d47_b. jpg
Thanks.
Ying
Previous Topic:How to run simple unit tests?
Next Topic:Starting comparison/Opening two files
Current Time: Mon Jul 21 21:22:25 EDT 2025
Powered by FUDForum. Page generated in 0.08072 seconds
