Home » Archived » BIRT » BIRT Report Object Model specs update
BIRT Report Object Model specs update [message #64950] Thu, 04 August 2005 14:43 Go to next message
The following BIRT Report Object Model specifications are updated on
the BIRT project website http://eclipse.org/birt/ref.
- ROM overview
- ROM base elements
- ROM design
- ROM layout
- ROM styles
- ROM scripting
The updates include some minor corrections based on community feedback.
Inconsistencies between the specifications and the 1.0,1.0.1 feature
descriptions have also been resolved.
Thanks.
--Rima Kanguri
Re: BIRT Report Object Model specs update [message #65268 is a reply to message #64950] Fri, 05 August 2005 12:14 Go to previous messageGo to next message
Rima,
Could you please explain where the ROM Spec for charting is located. I
am probably being dense, but I don't see it in the TOC or the specs.
Also, I see the FreeForm Element in there as since 1.0. I thought the
FreeForm element was planned for 2.0?
Scott Rosenbaum
BIRT PMC
Rima Kanguri wrote:
>Hi,
>- ROM overview
>- ROM base elements
>- ROM design
>- ROM layout
>- ROM styles
>- ROM scripting
>Thanks.
>--Rima Kanguri
Re: BIRT Report Object Model specs update [message #65332 is a reply to message #65268] Fri, 05 August 2005 17:56 Go to previous message
Scott,
The chart is implemented as a Report Item extension, therefore it is not
part of ROM specs.
We have plans to put a document describing the chart feature on the birt
website.
About FreeForm, it is not supported in 1.0, I will make the corrections in
the specs.
--Thanks
Rima Kanguri
Scott Rosenbaum wrote:
> Rima,
> Scott Rosenbaum
> BIRT PMC
> Rima Kanguri wrote:
> >Hi,
> >- ROM overview
> >- ROM base elements
> >- ROM design
> >- ROM layout
> >- ROM styles
> >- ROM scripting
> >Thanks.
> >--Rima Kanguri
Previous Topic:Any plan to support > 1 custom style selected for a single element?
Next Topic:problem generating pdf report with birt_1.0.1 report engine
Current Time: Tue Jul 22 14:36:35 EDT 2025
Powered by FUDForum. Page generated in 0.05615 seconds
