Home » Language IDEs » AspectJ » Initialization pointcut problem
Initialization pointcut problem [message #64862] Wed, 10 May 2006 09:59 Go to next message
Originally posted by: skirkaw.googlemail.com
I could not figure out the following initialization pointcut problem. Any
help would be appreciated.
Within the method of my class I do initialization of an object and would
like to replace this object with another object. Hence, I write an around
advice. But the poincut i write is not matched with the object in my class
methosd. To illustrate, the code is simply as follows:
class Test {
public void doTest() {
String s=new String("old String");
System.out.println(s);
// I would like to rewrite String s
public aspect TestAspect {
pointcut p(): initialization(String.new(String));
void around (): p() {
String s=new String("new String");
proceed();
But my pointcut p is not matched with the line "String s=new String("old
String");". What am I mssing?
Thanks in advance
Re: Initialization pointcut problem [message #65016 is a reply to message #64862] Fri, 19 May 2006 08:07 Go to previous message
To match calls to a constructor you need something like
"call(String.new(..))". Then to replace the object, you need to return
it from the around advice (and not call proceed). For example:
String around(): call(String.new(..)) && within(Test) {
return new String("new String");
Note also the "&& within(Test)" bit - you need to scope your pointcut
appropriately. This is good practice in general, but particularly
important here, otherwise your around advice would advise the call to
"new String" in its own body, leading to a stack overflow error.
Matt.
Steve kirkaw wrote:
> Any help would be appreciated.
> around advice. But the poincut i write is not matched with the object in
> my class methosd. To illustrate, the code is simply as follows:
> class Test {
> proceed();
> Thanks in advance
Re: Initialization pointcut problem [message #593703 is a reply to message #64862] Fri, 19 May 2006 08:07 Go to previous message
Matt.
Steve kirkaw wrote:
> class Test {
> proceed();
> Thanks in advance
Previous Topic:AJDT New Feature: Drag and drop aspects
Next Topic:cflow error :
Current Time: Sun Aug 31 04:26:23 EDT 2025
Powered by FUDForum. Page generated in 0.03266 seconds
