Home » Eclipse Projects » GEF » Need help fixing "class must implement abstract method" error !!
Need help fixing "class must implement abstract method" error !! [message #64857] Thu, 13 February 2003 09:55 Go to next message
Originally posted by: james48310.hotmail.com
Im trying to run the HelloGef2 example found on the webpage
http://eclipsewiki.swiki.net/50#logicexamplestandalone
but I get the error:
Class must implement the inherited abstract method
org.eclipse.gef.editparts.AbstractEditPart.createEditPolicie s()
The code where the error is found is posted below.
HelloConnectionEditPart.java
package org.eclipse.gef.examples.hellogef2;
import org.eclipse.draw2d.IFigure;
import org.eclipse.gef.editparts.AbstractConnectionEditPart;
public class HelloConnectionEditPart extends AbstractConnectionEditPart
thanks for any help!
Re: Need help fixing "class must implement abstract method" error !! [message #64884 is a reply to message #64857] Thu, 13 February 2003 15:35 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.planet-wagenknecht.de
"James" <james48310@hotmail.com> schrieb im Newsbeitrag
news:b2gbl5$1c2$1@rogue.oti.com...
There is an abstract method defined in AbstractEditPart which your EditPart
must implement.
Cu, Gunnar
Re: Need help fixing "class must implement abstract method" error !! [message #64905 is a reply to message #64884] Thu, 13 February 2003 18:19 Go to previous message
Gunnar Wagenknecht wrote:
> \\\"James\\\" <james48310@hotmail.com> schrieb im Newsbeitrag
> must implement.
> Cu, Gunnar
How do I do that? I tried making this change...
implements AbstractEditPart {}
..but that doesnt work.
Previous Topic:Figure is not a child of this parent
Next Topic:initial layout & createFigure()
Current Time: Sun Jul 27 02:48:39 EDT 2025
Powered by FUDForum. Page generated in 0.04737 seconds
