Home » Eclipse Projects » Nebula » Gantt: remove Connections
Gantt: remove Connections [message #64853] Fri, 19 June 2009 07:58 Go to next message
I want to show specific connections when a user clicks on a GanttEvent.
Of course I have to remove/hide the old ones, how can I do this? I tried
disposing all connections, but this yields a NPE. I changed the source
accordingly (set the GanttConnection's parent), but is there another
way?
this is what I do (essentially):
Collection<GanttConnection> connections = new
HashSet<GanttConnection>();
connections.addAll(ganttChart.getGanttComposite().getGanttCo nnections())
for (GanttConnection conn : connections)
conn.dispose();
n times:
ganttChart.addConnection(parentEvent, childEvent);
I I call this twice, I get an NPE at the conn.dispose() line
Manuel
Re: Gantt: remove Connections [message #64900 is a reply to message #64853] Sun, 21 June 2009 12:17 Go to previous messageGo to next message
Hi Manuel,
Can you post or send me the NPE? I'm not suggesting connections should be
disposed and re-set as that's not exactly intended behavor and I'm not all
too surprised that there may be issues doing it that way, but I'd still like
to see what the issue is :-)
As for what you're looking for, won't this ISetting give you what you want?
* Whether to only show the dependency connections only when an event is
selected, as opposed to always showing the lines.
* @return true if to show them only on selections. Default is false.
public boolean showOnlyDependenciesForSelectedItems();
Emil
"Manuel Steurer" <manuel.steurer@quattro-soft.de> wrote in message
news:h1fuhh$689$1@build.eclipse.org...
> way?
> conn.dispose();
> n times:
> Manuel
Re: Gantt: remove Connections [message #64939 is a reply to message #64900] Mon, 22 June 2009 07:55 Go to previous message
Hi Emil,
I attached a modified ConnectionExample-snippet. Works with your latest
nightly, not with the stable version though (where the GanttConnection
class does not exist yet as a public class).
To remedy the npe I did this to the GanttConnection package constructor:
GanttConnection(GanttComposite parent, GanttEvent source, GanttEvent
target,
Color color)
this._parent = parent;
this._source = source;
this._target = target;
this._color = color;
showOnlyDependenciesForSelectedItems is almost what I want, but I am
more flexible if I create the connections on the fly (see attached
screenshots)
(Although I'm not sure yet which connection-display-mode will actually
suit my needs better, showOnlyDependenciesForSelectedItems may also be
better performance-wise, if performance should ever be an issue.)
Greetings,
Manuel
Emil Crumhorn wrote:
> Hi Manuel,
> should be disposed and re-set as that's not exactly intended behavor
> and I'm not all too surprised that there may be issues doing it that
> way, but I'd still like to see what the issue is :-)
> want? /**
> event is selected, as opposed to always showing the lines. *
> Emil
> > Hi,
> > GanttEvent. Of course I have to remove/hide the old ones, how can
> > I do this? I tried disposing all connections, but this yields a
> > NPE. I changed the source accordingly (set the GanttConnection's
> > parent), but is there another way?
> > s()) ;
> > conn.dispose();
> > n times:
> > Thanks,
> > Manuel
Re: Gantt: remove Connections [message #595318 is a reply to message #64853] Sun, 21 June 2009 12:17 Go to previous message
Hi Manuel,
Emil
> way?
> conn.dispose();
> n times:
> Manuel
Re: Gantt: remove Connections [message #595337 is a reply to message #64900] Mon, 22 June 2009 07:55 Go to previous message
Hi Emil,
target,
Color color)
screenshots)
Greetings,
Manuel
> Hi Manuel,
> want? /**
> Emil
> > Hi,
> > s()) ;
> > conn.dispose();
> > n times:
> > Thanks,
> > Manuel
Previous Topic:help about gallery
Next Topic:Questions on Nebula Grid
Current Time: Sun Aug 31 12:54:46 EDT 2025
Powered by FUDForum. Page generated in 0.03913 seconds
