Home » Language IDEs » PHP Development Tools (PDT) » Code completion assistant
Code completion assistant [message #64851] Mon, 21 January 2008 21:33 Go to next message
Originally posted by: onkr.op.pl
Is there a way to tell eclipse that certain variable is actually an
object of class xyz so code completion assistant can suggest methods.
I guess the best way to explain what I'm referring to is an example:
//Class A and B are implementing the same interface or abstract class.
class A extends AbstractClass{
function method1(){...}
function method2(){...}
function method3(){...}
class A extends AbstractClass {
//Factory class
class FAC{
public static function Create($something){
if($something){
return new A();
}else{
return new B();
$example = FAC::Create(1);
Now when I use $example eclipse code completion assistant is not
suggesting anything to me. Is there a way to tell Eclipse that the
$example is object of class A or B?
Ralph
Re: Code completion assistant [message #64874 is a reply to message #64851] Tue, 22 January 2008 03:13 Go to previous messageGo to next message
Ralph wrote:
> Hi
> //Factory class
> class FAC{
> if($something){
> return new A();
> }else{
> return new B();
> Ralph
try phpdoc comments:
* @return AbstractClass
Re: Code completion assistant [message #64895 is a reply to message #64874] Tue, 22 January 2008 09:32 Go to previous message
WORKS !!!
Thank you!
Previous Topic:Information about Eclipse 1.0.2
Next Topic:Variables in code templates
Current Time: Sun Aug 31 23:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.03351 seconds
