Re: [Teneo] Cascading dilemma. [message #645735 is a reply to message #645460] |
Mon, 20 December 2010 10:02 |
Hi Christophe,
The reason that the copy-paste does not work is because of the delete-orphan cascading setting. I think you saw this
part of the wiki already:
http://wiki.eclipse.org/Teneo/Hibernate/EMF_Hibernate_Integr ation_Details#Move_an_EObject_between_EContainers_or_support _cut_and_paste_in_the_EMF_editor
I think to solve this issue you have to set this option:
teneo.mapping.cascade_policy_on_containment
to:
REMOVE, REFRESH, PERSIST, MERGE
You can also set default cascade options for non-containment associations, see this page:
http://wiki.eclipse.org/Teneo/Hibernate/Configuration_Option s
gr. Martin
On 12/17/2010 10:56 AM, Christophe Bouhier wrote:
> I have two requirements which force me to have different cascading policies. It seems, I would need different cascading
> options as concurring actions can't co-exist (At least this is what I seem to experience). Is there a way to do this
> without initializing the datastore? (On the fly?).
> The two cases are:
> 1. Moving objects in a tree (Using a Hibernate Resource)-> Requires the casding policy to be
> props.setProperty(PersistenceOptions.SET_CASCADE_ALL_ON_CONT AINMENT, "false");
> (Moving would throw a Hibernate exception).
> 2. Saving the complete content of an EObject root to Hibernate, which will throw an exception with the above option on.
> (I previously asked about this, and the following option was advised:
> props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_CONTA INMENT,
> "ALL");
> 10:51:45,174 ERROR AbstractFlushingEventListener:324 - Could not synchronize database state with session
> org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance
> before flushing: Equipment
> at org.hibernate.engine.ForeignKeys.getEntityIdentifierIfNotUns aved(ForeignKeys.java:242)
> at org.hibernate.type.EntityType.getIdentifier(EntityType.java: 430)
> at org.hibernate.type.ManyToOneType.nullSafeSet(ManyToOneType.j ava:101)
> at org.hibernate.persister.collection.AbstractCollectionPersist er.writeElement(AbstractCollectionPersister.java:777)
> at org.hibernate.persister.collection.AbstractCollectionPersist er.recreate(AbstractCollectionPersister.java:1165)
> at org.hibernate.action.CollectionRecreateAction.execute(Collec tionRecreateAction.java:58)
> at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:27 9)
> Here is the code:
> // Make a copy.
> EcoreUtil.Copier copier = new EcoreUtil.Copier();
> EObject copy = copier.copy(root);
> copier.copyReferences();
> Session session = TeneoService.getInstance().getSession();
> Transaction tx = session.beginTransaction();
> // Save our new copy.
> session.save(copy);
> try {
> tx.commit();
> } catch (Exception e) {
> if (tx != null)
> tx.rollback();
> return null;
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Cascading dilemma. [message #645908 is a reply to message #645735] |
Tue, 21 December 2010 06:31 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
Thanks Martin,
This seems to solve the issue.
Cheers Christophe
On 20-12-10 11:02, Martin Taal wrote:
> Hi Christophe,
> delete-orphan cascading setting. I think you saw this part of the wiki
> already:
> to:
> gr. Martin
>> Hi,
>> The two cases are:
>> "false");
>> "ALL");
>> at
>> at
>> at
>> at
>> Here is the code:
>> // Make a copy.
>> session.save(copy);
>> try {
>> tx.commit();
>> if (tx != null)
>> tx.rollback();
>> return null;
FUDForum. Page generated in 0.03923 seconds
