any update to installation bug [message #64817] |
Thu, 20 March 2003 09:53  |
Judy had posted a workaround for some installation problems, but I (and
several others) keep getting the following problem (quoting from my
previous post):
---Start quote
I've tried this and it still doesn't work - but I did find a possible
cause. This is the error I get after pressing "Enable" in the
Install/Update Manager:
Error creating feature "file:/C:/Program Files/eclipse/eclipse
2.0.2/features/org.eclipse.cdt_1.0.1.jar/".[java.io.FileNotFoundException:
C:\Program Files\eclipse\eclipse
2.0.2\features\org.eclipse.cdt_1.0.1.jar\feature.xml
The problem seems to be that it's looking for
"features/org.eclipse.cdt_1.0.1.jar", when the zip expansion actually
creates "features/org.eclipse.cdt_1.0.1" (no ".jar").
---End quote
I am running Windows 2000, using Eclipse 2.0.2, trying to install 1.0.1
GA. Has there been any fix to this? I'd really like to try out this plug
in for my C/C++ programming.
Josh
Re: any update to installation bug [message #65013 is a reply to message #64817] |
Sun, 23 March 2003 22:38   |
I too have been hoping for an update on the installation bug. I have also
tried all the work arounds and posted solutions from several different
posts in this forum. None of them have worked successfully for me. I am
running Windows XP and using Eclipse 2.1 (various versions) for Java
devlopment, but tried the latest CDT plugin on Eclipse 2.02 without
success. I love using Eclipse for my fully time Java development
environment, but haven't done any serious C++ development as of yet.
I appreciate all the work you guys have been doing on the CDT plugin, just
wondering (like Josh) if any progress has been made with these
installation problems.
As a side note, is there a rough timeline for a CDT plugin that
(officially) works with Eclipse 2.1? I've been using the 1.0 CDT build
with Eclipse 2.1 without any major problems, but I know it's not the
official version that it's supposed to be used with. I realize that this
won't be for a while (Eclipse 2.1 isn't even finalized yet), just
wondering if there is some idea of when this will happen.
Ben Plantinga
> previous post):
> ---Start quote
> ---End quote
> Josh
Re: any update to installation bug [message #65527 is a reply to message #64817] |
Tue, 01 April 2003 12:34   |
I'm trying to install cdt with eclipse 2.1 on Linux (I know, I know, its
not supposed to work)
and I'm getting the same error message when trying to activate the cdt.
- After doing the show disabled->activate (described in some posts
earlier), I tried jarring up /features/org.eclipse.cdt_1.0.1, creating a
symbolic link with the .jar extension pointing to the
org.eclipse.cdt_1.0.1 directory and creating a copy of the
org.eclipse.cdt_1.0.1 directory , naming it org.eclipse.cdt_1.0.1.jar -
with no success.
I'm going to wait awhile to see if anyone else gets it to work or until
its officially supported - whatever comes first.
If anyone has managed to get around this - I would really appreciate
some advice (I haven't been able to find a
workaround that works in this newsgroup yet).
/m
> previous post):
> ---Start quote
> ---End quote
> Josh
Re: any update to installation bug [message #65548 is a reply to message #65527] |
Tue, 01 April 2003 13:18   |
Ok - I just tried the nightly build
(org.eclipse.cdt-200303270414-linux-gtk_1.0.1.bin.dist.zip) instead of the
one below. It worked (without any tricky workarounds) like a charm.
This is soooo nice. Thanx for the great work!!
/m
> with no success.
> Cheers,
> /m
>> previous post):
>> ---Start quote
>> ---End quote
>> Thanks,
>> Josh
Re: any update to installation bug [message #66311 is a reply to message #64817] |
Tue, 08 April 2003 15:28  |
Update: the latest nightly build (3/27) seems to have fixed the error,
but seems to have the bug that doesn't let the C++ Editor open up
(requires one to open C++ files in the standard text editor)! Any idea on
when this will be fixed?
Josh
> previous post):
> ---Start quote
> ---End quote
> Josh
FUDForum. Page generated in 0.05433 seconds
