jdk version [message #64813] |
Fri, 09 July 2004 14:11  |
Originally posted by: songwang.gmail.com
hi,
I installed eclipse 3.0 and when run it by clicking on the eclipse.exe, I
got a error message asking for jdk1.4.1 or above. i downloaded 1.4.1 and
installed, but eclipse still issuing the same message.
I know I can invoke eclipse from command line specify the jvm location,
but is there any simpler way to let eclipse get the right jvm which is
already installed on my machine.
thanks
Re: jdk version [message #64877 is a reply to message #64858] |
Mon, 12 July 2004 15:03  |
You can change your JAVA_HOME var to reflect the JRE you want to use... This
will eliminate other java problems your machine.
Mine is set to: JAVA_HOME =C:\Program Files\Java\jre1.5.0\bin
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:ccu0uk$rdl$2@eclipse.org...
> allen wrote:
> >hi,
> Start eclipse.exe with -vm <your vm goes here>
> Dani
> >thanks
Re: jdk version [message #597784 is a reply to message #64813] |
Mon, 12 July 2004 08:43  |
Originally posted by: daniel.megert.gmx.net
allen wrote:
>hi,
Dani
>thanks
Re: jdk version [message #597788 is a reply to message #64858] |
> allen wrote:
> >hi,
> Dani
> >thanks
FUDForum. Page generated in 0.04318 seconds
