Home » Language IDEs » C / C++ IDE (CDT) » Need help creating a run configuration
Need help creating a run configuration [message #64772] Wed, 19 March 2003 14:12 Go to next message
Originally posted by: acme.us.ibm.com
When creating a run configuration, are there restrictions on what you
can set as the C/C++ Application? My project is a shared library that
gets loaded by an executable that I don't own. I need to specify the
executable that is off in a shared directory as the application, but
can't seem to get it to work. Any help would be appreciated.
Bryan
Re: Need help creating a run configuration [message #64795 is a reply to message #64772] Wed, 19 March 2003 16:24 Go to previous message
I figured it out. If you make a link to the executable to your project
directory, you can then access it in the run configuration.
Bryan
Previous Topic:Unable to open cpp file from cdt
Next Topic:Debugger timeout when launching a debug session
Current Time: Tue Jul 22 01:33:13 EDT 2025
Powered by FUDForum. Page generated in 0.28049 seconds
