Home » Archived » Visual Editor (VE) » JFrame Application terminate
JFrame Application terminate [message #64731] Tue, 05 October 2004 08:46 Go to next message
Originally posted by: carsten.kohlhausen
i create a new visual class which extends JFrame with ve wizard. Every
time i execute this class, i receive the message "terminate".
What do i wrong?
Carsten
Re: JFrame Application terminate [message #64775 is a reply to message #64731] Tue, 05 October 2004 10:25 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Carsten wrote:
> What do i wrong?
> Carsten
Most likely you chose to create a main method while creating the class,
and you're using Run As->Java Application rather than Run As->Java Bean.
Java Application runs the main method, and the VE doesn't put any code
into your main method.
- Jeff
Re: JFrame Application terminate [message #600817 is a reply to message #64731] Tue, 05 October 2004 10:25 Go to previous message
Carsten wrote:
> What do i wrong?
> Carsten
- Jeff
Previous Topic:JFrame Application terminate
Next Topic:Newbie: No New Java Visual Class Wizard
Current Time: Tue Jul 22 21:20:08 EDT 2025
Powered by FUDForum. Page generated in 0.03573 seconds
