Proper usage of diagram node selection and subsequent command processing [message #64725] |
Tue, 17 October 2006 17:44  |
due to some bug that has turned out to be quite mysterious, I would like
to clarify some things:
(1)
Why get methods like e.g. PackageEditHelper.getMoveCommand(MoveRequest
req) executed 3-5 times in a row when I do a drag'n'drop operation (with
a single diagram element!) in my diagram?
Not only I wonder why that method is called multiple times, but also the
fact that the number of subsequent calls varies.
Further, I do expect that method to be called not earlier then the
"release mouse button event". Instead, it's called on mouse hover (with
dragged elements glued to the mouse pointer).
(2)
I feel that there are some things to know concerning proper selection of
multiple diagram nodes. In particular, how do I access the set of
currently active diagram elements?
(3, as a consequence of 1+2)
When will the runtime documentation and related docs be reviewed to
cover these nasty things?
Thanks a lot for your advice,
Martin Herbort
Re: Proper usage of diagram node selection and subsequent command processing [message #64750 is a reply to message #64725] |
Tue, 17 October 2006 18:39  |
Originally posted by: vcciubot.uwaterloo.ca
> (1)
Tools/Actions etc call getCommand() on an EditPart to update the mouse
pointer or their icon (enabled/disabled). As such, when you drag the tool
updates the target edit part and calls getCommand() on that edit part
which in turn calls the semantic policy which calls your edit helper.
Those commands are checked for being executable but are only executed when
the dragging ends.
> (2)
EditPartViewer#getSelection
You can get the viewer from an edit part.
It's hard at the beginning :)
Some of these topics have already been covered in the GEF programmer's
manual.
FUDForum. Page generated in 0.26269 seconds
