Eclipse and CVS [message #64721] |
Thu, 05 June 2003 17:28  |
Originally posted by: tlondon.projtech.com
I am running eclipse with bugzilla, cvs, and CVSZilla. It fails when trying
to share a project, because I am required to enter a bug id for bugzilla.
You are not given a chance to enter a log message when sharing a project,
therefore I am unable to enter the bug id. Has anyone else ran into this
problem? If so have you found a fix?
Thank you in advance,
Travis London
Re: Eclipse and CVS [message #65284 is a reply to message #64721] |
Fri, 06 June 2003 06:26  |
Currently you can't enter a comment on the initial import. As a
workaround import via the command line using a comment then return to
Eclipse, refresh local, then share the project with CVS. The CVSness
of the project will be detected automatically.
Subsequent commit operations will allow comments. Please enter a feature
request for supporting comment on initial share.
Jean-Michel
> Travis London
FUDForum. Page generated in 0.03929 seconds
