Home » Eclipse Projects » Plugin Development Environment (PDE) » Update Manager issue
Update Manager issue [message #64720] Thu, 11 June 2009 15:13 Go to next message
I have built my application using Eclipse 3.4, but when I select the Help
menu, the "Software Updates ->" menu selection contains "Find and Install"
and
"Manage Configuration", instead of the new P2 style of menu selection
"Software Updates..." which when selected brings up the "Software Updates
and Add-ons" dlg.
How can I make my application bring up the new P2 style update manager
menu selections?
Thanks for any help you can offer.
Best Regards,
Lisa Jett
Re: Update Manager issue [message #64745 is a reply to message #64720] Fri, 12 June 2009 05:06 Go to previous messageGo to next message
Lisa Jett wrote:
> Help menu, the "Software Updates ->" menu selection contains "Find and
> Install" and "Manage Configuration", instead of the new P2 style of menu
> selection "Software Updates..." which when selected brings up the
> "Software Updates and Add-ons" dlg.
> menu selections?
> Best Regards,
> Lisa Jett
Go to Windows - Preferences -> General -> capabilities
Uncheck the "classic update". restart eclipse (if required).
hth,
Ankur..
Re: Update Manager issue [message #64790 is a reply to message #64745] Fri, 12 June 2009 10:13 Go to previous messageGo to next message
Thanks for the suggestion, but I do not have a "Classic Update" option to
uncheck. I only have "Development" and "Team".
Something about my PDE build is preventing me from having that option &
from having the P2 style "Software Updates..." menu in my application.
Do you know what plugin I need to remove to get rid of the old-style
update manager from my application?
Re: Update Manager issue [message #64837 is a reply to message #64745] Fri, 12 June 2009 12:16 Go to previous messageGo to next message
I do not have a "Classic Update" checkbox to uncheck. I have the p2
plugins in my application, as well as the org.eclipse.update.* plugins.
For some reason, the old-style Software Updates -> Find and Install and
Software Updates -> Manage Configuration menu items are being displayed,
instead of the p2 "Software Updates..." menu item.
What determines which menu item gets displayed?
Re: Update Manager issue [message #65348 is a reply to message #64837] Tue, 23 June 2009 12:58 Go to previous message
Originally posted by: iloncar.mlIQTEST.gmail.com
Hello Lisa,
> plugins. For some reason, the old-style Software Updates -> Find and
> Install and Software Updates -> Manage Configuration menu items are
> being displayed, instead of the p2 "Software Updates..." menu item.
IIRC you get old style update manager with SDK or PDE package. It's not in
every EPP. I may be wrong.
Ivica Loncar
Re: Update Manager issue [message #598282 is a reply to message #64720] Fri, 12 June 2009 05:06 Go to previous message
Lisa Jett wrote:
> menu selections?
> Best Regards,
> Lisa Jett
hth,
Ankur..
Re: Update Manager issue [message #598292 is a reply to message #64745] Fri, 12 June 2009 10:13 Go to previous message
Re: Update Manager issue [message #598306 is a reply to message #64745] Fri, 12 June 2009 12:16 Go to previous message
Re: Update Manager issue [message #598502 is a reply to message #64837] Tue, 23 June 2009 12:58 Go to previous message
Hello Lisa,
Ivica Loncar
Previous Topic:External tool implementation
Next Topic:PDE Build errors on xerces jar
Current Time: Sat Jul 05 05:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.06844 seconds
