Home » Eclipse Projects » Nebula » Row-wise table editing
| Row-wise table editing [message #64712] |
Fri, 19 June 2009 04:15  |
Originally posted by: m.kasid.gmail.com
Is there a support to have different editors on different rows of Nebula
grid? Currently, we can have editors (text, combo etc.) on columns and this
would mean it will display the same editor for that column in all the
rows...My requirement is something kind of a Transposed table. Is it
possible with Nebula Grid?
Mustufa
| Re: Row-wise table editing [message #64804 is a reply to message #64781] |
Fri, 19 June 2009 05:03   |
Hi Tom,
I think you got my question that I want a viewer where Columns are the
dynamic part. Sorry for the confusion. The previous question was related to
this one as i want dynamic columns plus different editor on each row.
Your suggestion about transforming Column model to Row model could be
explored (it will too complicated though). I was just looking if there is
some inbuilt facility already provided by Nebula Grid.
Anyways, Thanks a lot for the answers.
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:h1fjhu$hmj$1@build.eclipse.org...
> Sorry I don't get the problem. Whenever the viewer wants to show an
> editor he asks the EditingSupport for one.
> Based on the information provided to you (you know the column and you
> get the domain-object representing the row) you can switch your editor
> for every single cell.
> Are you asking for a viewer where the Columns are the dynamic part
> instead of the rows? Then this is not possible but you should be able to
> handle this at the model part by transforming your column domain model
> into a row model and feeding it into the viewer. But you original
> question was about something completely different so I'm not sure I
> understood your problem.
> Tom
> Mustufa Kasidwala schrieb:
>> Hi Tom,
>> Thanks for the reply. Yes i did went through the idea you provided in
>> this
>> article. I can see that you are using Model which is represented in Rows,
>> although this is the obvious approach of TableViewer/Nebul Grid, my
>> requirement extends further to the fact that I need Model represented by
>> Columns rather than rows. Is that possible using the inbuild JFace APIs?
>> or
>> i will have to do something manually to manage the Model input/output ?
>> Consider a normal Nebula Grid editor but Rows will take place of Columns
>> and
>> vice-versa.
>> Thanks
>> Mustufa
>> news:h1fi0u$sh9$1@build.eclipse.org...
>>> Hi,
>>> Yes this is supported using JFace 3.3 API named EditingSupport where you
>>> are asked every time for an editor before displaying it.
>>> You can simply use the code from
>>> http://wiki.eclipse.org/JFaceSnippets#Snippet034CellEditorPe rRowNewAPI
>>> This is a general rule everything available from JFace upstream is
>>> available in the Nebula-Grid-Viewer (with small exception when it comes
>>> to Grid-TreeViewer) else it is a bug and needs fixing.
>>> Tom
>>>> Hi,
>>>> Nebula
>>>> this
>>>> Thanks
>>>> Mustufa
| Re: Row-wise table editing [message #64830 is a reply to message #64804] |
Fri, 19 June 2009 06:49   |
--------------070401020909050409020601
Content-Type: text/plain; charset=ISO-8859-15
There no such support for this but IMHO transforming a Row-Model into
Column-Model isn't a problem. Using reflection this is done quite easily
in a generic manner.
I just gave it a try and came up with the snippet attached to this mail
and available from our snippets collection.
Tom
> Hi Tom,
>> Tom
>>> Hi Tom,
>>> this
>>> or
>>> and
>>> vice-versa.
>>> Thanks
>>> Mustufa
>>>> Hi,
>>>> Tom
>>>>> Hi,
>>>>> Nebula
>>>>> this
>>>>> Thanks
>>>>> Mustufa
name="GridViewerSnippet7.java"
Content-Disposition: inline;
filename="GridViewerSnippet7.java"
LyoqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioq
KioqKioqKioqKioqKioqKioqKioqKioqKioKICogQ29weXJpZ2h0IChjKSAy MDA5IFRvbSBT
Y2hpbmRsIGFuZCBvdGhlcnMuCiAqIEFsbCByaWdodHMgcmVzZXJ2ZWQuIFRo aXMgcHJvZ3Jh
bSBhbmQgdGhlIGFjY29tcGFueWluZyBtYXRlcmlhbHMKICogYXJlIG1hZGUg YXZhaWxhYmxl
IHVuZGVyIHRoZSB0ZXJtcyBvZiB0aGUgRWNsaXBzZSBQdWJsaWMgTGljZW5z ZSB2MS4wCiAq
IHdoaWNoIGFjY29tcGFuaWVzIHRoaXMgZGlzdHJpYnV0aW9uLCBhbmQgaXMg YXZhaWxhYmxl
IGF0CiAqIGh0dHA6Ly93d3cuZWNsaXBzZS5vcmcvbGVnYWwvZXBsLXYxMC5o dG1sCiAqCiAq
IENvbnRyaWJ1dG9yczoKICogICAgIFRvbSBTY2hpbmRsIC0gaW5pdGlhbCBB UEkgYW5kIGlt
cGxlbWVudGF0aW9uCiAqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioq
KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqLwpwYWNr YWdlIG9yZy5l
Y2xpcHNlLnN3dC5uZWJ1bGEuc25pcHBldHMuZ3JpZC52aWV3ZXI7CgppbXBv cnQgamF2YS5i
ZWFucy5CZWFuSW5mbzsKaW1wb3J0IGphdmEuYmVhbnMuSW50cm9zcGVjdGlv bkV4Y2VwdGlv
bjsKaW1wb3J0IGphdmEuYmVhbnMuSW50cm9zcGVjdG9yOwppbXBvcnQgamF2 YS5iZWFucy5Q
cm9wZXJ0eURlc2NyaXB0b3I7CmltcG9ydCBqYXZhLnRleHQuTnVtYmVyRm9y bWF0OwppbXBv
cnQgamF2YS50ZXh0LlBhcnNlRXhjZXB0aW9uOwppbXBvcnQgamF2YS50ZXh0 LlNpbXBsZURh
dGVGb3JtYXQ7CmltcG9ydCBqYXZhLnV0aWwuQXJyYXlMaXN0OwppbXBvcnQg amF2YS51dGls
LkRhdGU7CmltcG9ydCBqYXZhLnV0aWwuTGlzdDsKaW1wb3J0IG9yZy5lY2xp cHNlLmpmYWNl
LnJlc291cmNlLkltYWdlRGVzY3JpcHRvcjsKaW1wb3J0IG9yZy5lY2xpcHNl LmpmYWNlLnJl
c291cmNlLkltYWdlUmVnaXN0cnk7CmltcG9ydCBvcmcuZWNsaXBzZS5qZmFj ZS52aWV3ZXJz
LkNlbGxFZGl0b3I7CmltcG9ydCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJz LkNvbHVtbkxh
YmVsUHJvdmlkZXI7CmltcG9ydCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJz LkNvbHVtblZp
ZXdlcjsKaW1wb3J0IG9yZy5lY2xpcHNlLmpmYWNlLnZpZXdlcnMuRWRpdGlu Z1N1cHBvcnQ7
CmltcG9ydCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLklTdHJ1Y3R1cmVk Q29udGVudFBy
b3ZpZGVyOwppbXBvcnQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5UZXh0 Q2VsbEVkaXRv
cjsKaW1wb3J0IG9yZy5lY2xpcHNlLmpmYWNlLnZpZXdlcnMuVmlld2VyOwpp bXBvcnQgb3Jn
LmVjbGlwc2UubmVidWxhLmpmYWNlLmdyaWR2aWV3ZXIuR3JpZFRhYmxlVmll d2VyOwppbXBv
cnQgb3JnLmVjbGlwc2UubmVidWxhLmpmYWNlLmdyaWR2aWV3ZXIuR3JpZFZp ZXdlckNvbHVt
bjsKaW1wb3J0IG9yZy5lY2xpcHNlLnN3dC5TV1Q7CmltcG9ydCBvcmcuZWNs aXBzZS5zd3Qu
ZXZlbnRzLlZlcmlmeUV2ZW50OwppbXBvcnQgb3JnLmVjbGlwc2Uuc3d0LmV2 ZW50cy5WZXJp
ZnlMaXN0ZW5lcjsKaW1wb3J0IG9yZy5lY2xpcHNlLnN3dC5sYXlvdXQuRmls bExheW91dDsK
aW1wb3J0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkNvbXBvc2l0ZTsKaW1w b3J0IG9yZy5l
Y2xpcHNlLnN3dC53aWRnZXRzLkRpc3BsYXk7CmltcG9ydCBvcmcuZWNsaXBz ZS5zd3Qud2lk
Z2V0cy5TaGVsbDsKaW1wb3J0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLlRl eHQ7CgovKioK
ICogQ3JlYXRpbmcgYSB2aWV3ZXIgd2hlcmUgY29sdW1ucyBhcmUgZHluYW1p YwogKiAKICog
QGF1dGhvciBUb20gU2NoaW5kbCA8dG9tLnNjaGluZGxAYmVzdHNvbHV0aW9u LmF0PgogKi8K
cHVibGljIGNsYXNzIEdyaWRWaWV3ZXJTbmlwcGV0NyB7Cglwcml2YXRlIHN0 YXRpYyBjbGFz
cyBDb21taXR0ZXIgewoJCXByaXZhdGUgU3RyaW5nIG5hbWU7CgkJcHJpdmF0 ZSBEYXRlIGJp
cnRoZGF5OwoJCXByaXZhdGUgaW50IGNvbW1pdHM7CgkJcHJpdmF0ZSBpbnQg YnVnczsKCgkJ
cHVibGljIENvbW1pdHRlcihTdHJpbmcgbmFtZSwgRGF0ZSBiaXJ0aGRheSwg aW50IGNvbW1p
dHMsIGludCBidWdzKSB7CgkJCXRoaXMubmFtZSA9IG5hbWU7CgkJCXRoaXMu YmlydGhkYXkg
PSBiaXJ0aGRheTsKCQkJdGhpcy5jb21taXRzID0gY29tbWl0czsKCQkJdGhp cy5idWdzID0g
YnVnczsKCQl9CgoJCXB1YmxpYyBTdHJpbmcgZ2V0TmFtZSgpIHsKCQkJcmV0 dXJuIG5hbWU7
CgkJfQoKCQlAU3VwcHJlc3NXYXJuaW5ncygidW51c2VkIikKCQlwdWJsaWMg dm9pZCBzZXRO
YW1lKFN0cmluZyBuYW1lKSB7CgkJCXRoaXMubmFtZSA9IG5hbWU7CgkJfQoK CQlAU3VwcHJl
c3NXYXJuaW5ncygidW51c2VkIikKCQlwdWJsaWMgaW50IGdldENvbW1pdHMo KSB7CgkJCXJl
dHVybiBjb21taXRzOwoJCX0KCgkJQFN1cHByZXNzV2FybmluZ3MoInVudXNl ZCIpCgkJcHVi
bGljIHZvaWQgc2V0Q29tbWl0cyhpbnQgY29tbWl0cykgewoJCQl0aGlzLmNv bW1pdHMgPSBj
b21taXRzOwoJCX0KCgkJQFN1cHByZXNzV2FybmluZ3MoInVudXNlZCIpCgkJ cHVibGljIGlu
dCBnZXRCdWdzKCkgewoJCQlyZXR1cm4gYnVnczsKCQl9CgoJCUBTdXBwcmVz c1dhcm5pbmdz
KCJ1bnVzZWQiKQoJCXB1YmxpYyB2b2lkIHNldEJ1Z3MoaW50IGJ1Z3MpIHsK CQkJdGhpcy5i
dWdzID0gYnVnczsKCQl9CgoJCUBTdXBwcmVzc1dhcm5pbmdzKCJ1bnVzZWQi KQoJCXB1Ymxp
YyBEYXRlIGdldEJpcnRoZGF5KCkgewoJCQlyZXR1cm4gYmlydGhkYXk7CgkJ fQoKCQlAU3Vw
cHJlc3NXYXJuaW5ncygidW51c2VkIikKCQlwdWJsaWMgdm9pZCBzZXRCaXJ0 aGRheShEYXRl
IGJpcnRoZGF5KSB7CgkJCXRoaXMuYmlydGhkYXkgPSBiaXJ0aGRheTsKCQl9 Cgl9CgoJcHJp
dmF0ZSBzdGF0aWMgaW50ZXJmYWNlIElNZWRpYXRvciB7CgkJcHVibGljIE9i amVjdCBnZXRW
YWx1ZShpbnQgaW5kZXgpOwoKCQlwdWJsaWMgdm9pZCBzZXRWYWx1ZShpbnQg aW5kZXgsIE9i
amVjdCB2YWx1ZSk7CgoJCXB1YmxpYyBDbGFzczw/PiBnZXRUeXBlKGludCBp bmRleCk7CgoJ
CXB1YmxpYyBTdHJpbmcgZ2V0UHJvcGVydHlOYW1lKCk7Cgl9CgoJcHJpdmF0 ZSBzdGF0aWMg
Y2xhc3MgTWVkaWF0b3IgaW1wbGVtZW50cyBJTWVkaWF0b3IgewoJCXByaXZh dGUgTGlzdDxP
YmplY3Q+IGRvbWFpbk9iamVjdHM7CgkJcHJpdmF0ZSBTdHJpbmcgcHJvcGVy dHlOYW1lOwoJ
CXByaXZhdGUgUHJvcGVydHlEZXNjcmlwdG9yIGRlc2NyaXB0b3I7CgoJCXB1 YmxpYyBNZWRp
YXRvcihMaXN0PD8+IGRvbWFpbk9iamVjdHMsIFN0cmluZyBwcm9wZXJ0eU5h bWUpIHsKCQkJ
dGhpcy5kb21haW5PYmplY3RzID0gbmV3IEFycmF5TGlzdDxPYmplY3Q+KGRv bWFpbk9iamVj
dHMpOwoJCQl0aGlzLnByb3BlcnR5TmFtZSA9IHByb3BlcnR5TmFtZTsKCgkJ CUJlYW5JbmZv
IGJlYW5JbmZvOwoJCQl0cnkgewoJCQkJYmVhbkluZm8gPSBJbnRyb3NwZWN0 b3IuZ2V0QmVh
bkluZm8oZG9tYWluT2JqZWN0cy5nZXQoMCkKCQkJCQkJLmdldENsYXNzKCkp OwoJCQkJUHJv
cGVydHlEZXNjcmlwdG9yW10gcHJvcGVydHlEZXNjcmlwdG9ycyA9IGJlYW5J bmZvCgkJCQkJ
CS5nZXRQcm9wZXJ0eURlc2NyaXB0b3JzKCk7CgoJCQkJZm9yIChpbnQgaSA9 IDA7IGkgPCBw
cm9wZXJ0eURlc2NyaXB0b3JzLmxlbmd0aDsgaSsrKSB7CgkJCQkJUHJvcGVy dHlEZXNjcmlw
dG9yIGRlc2NyaXB0b3IgPSBwcm9wZXJ0eURlc2NyaXB0b3JzW2ldOwoJCQkJ CWlmIChkZXNj
cmlwdG9yLmdldE5hbWUoKS5lcXVhbHMocHJvcGVydHlOYW1lKSkgewoJCQkJ CQl0aGlzLmRl
c2NyaXB0b3IgPSBkZXNjcmlwdG9yOwoJCQkJCQlicmVhazsKCQkJCQl9CgkJ CQl9CgkJCX0g
Y2F0Y2ggKEludHJvc3BlY3Rpb25FeGNlcHRpb24gZSkgewoJCQkJZS5wcmlu dFN0YWNrVHJh
Y2UoKTsKCQkJfQoJCX0KCgkJcHVibGljIE9iamVjdCBnZXRWYWx1ZShpbnQg aW5kZXgpIHsK
CQkJdHJ5IHsKCQkJCWlmIChkb21haW5PYmplY3RzLnNpemUoKSA+IGluZGV4 KSB7CgkJCQkJ
cmV0dXJuIGRlc2NyaXB0b3IuZ2V0UmVhZE1ldGhvZCgpLmludm9rZSgKCQkJ CQkJCWRvbWFp
bk9iamVjdHMuZ2V0KGluZGV4KSwgbmV3IE9iamVjdFswXSk7CgkJCQl9CgkJ CX0gY2F0Y2gg
KEV4Y2VwdGlvbiBlKSB7CgkJCQllLnByaW50U3RhY2tUcmFjZSgpOwoJCQl9 CgkJCXJldHVy
biBudWxsOwoJCX0KCgkJcHVibGljIHZvaWQgc2V0VmFsdWUoaW50IGluZGV4 LCBPYmplY3Qg
dmFsdWUpIHsKCQkJdHJ5IHsKCQkJCWlmIChkb21haW5PYmplY3RzLnNpemUo KSA+IGluZGV4
KSB7CgkJCQkJZGVzY3JpcHRvci5nZXRXcml0ZU1ldGhvZCgpLmludm9rZSgK CQkJCQkJCWRv
bWFpbk9iamVjdHMuZ2V0KGluZGV4KSwgdmFsdWUpOwoJCQkJfQoJCQl9IGNh dGNoIChFeGNl
cHRpb24gZSkgewoJCQkJZS5wcmludFN0YWNrVHJhY2UoKTsKCQkJfQoJCX0K CgkJcHVibGlj
IENsYXNzPD8+IGdldFR5cGUoaW50IGluZGV4KSB7CgkJCXJldHVybiBkZXNj cmlwdG9yLmdl
dFByb3BlcnR5VHlwZSgpOwoJCX0KCgkJcHVibGljIFN0cmluZyBnZXRQcm9w ZXJ0eU5hbWUo
KSB7CgkJCXJldHVybiBwcm9wZXJ0eU5hbWU7CgkJfQoJfQoKCXByaXZhdGUg c3RhdGljIGNs
YXNzIExhYmVsUHJvdmlkZXJJbXBsIGV4dGVuZHMgQ29sdW1uTGFiZWxQcm92 aWRlciB7CgkJ
cHJpdmF0ZSBpbnQgY29sSW5kZXg7CgoJCXB1YmxpYyBMYWJlbFByb3ZpZGVy SW1wbChpbnQg
Y29sSW5kZXgpIHsKCQkJdGhpcy5jb2xJbmRleCA9IGNvbEluZGV4OwoJCX0K CgkJQE92ZXJy
aWRlCgkJcHVibGljIFN0cmluZyBnZXRUZXh0KE9iamVjdCBlbGVtZW50KSB7 CgkJCUlNZWRp
YXRvciBtID0gKElNZWRpYXRvcikgZWxlbWVudDsKCQkJaWYgKG0uZ2V0VHlw ZShjb2xJbmRl
eCkgPT0gaW50LmNsYXNzKSB7CgkJCQlyZXR1cm4gTnVtYmVyRm9ybWF0Lmdl dEludGVnZXJJ
bnN0YW5jZSgpLmZvcm1hdCgKCQkJCQkJbS5nZXRWYWx1ZShjb2xJbmRleCkp OwoJCQl9IGVs
c2UgaWYgKG0uZ2V0VHlwZShjb2xJbmRleCkgPT0gRGF0ZS5jbGFzcykgewoJ CQkJcmV0dXJu
IG5ldyBTaW1wbGVEYXRlRm9ybWF0KCJ5eXl5LU1NLWRkIikuZm9ybWF0KAoJ CQkJCQltLmdl
dFZhbHVlKGNvbEluZGV4KSk7CgkJCX0KCQkJcmV0dXJuIHN1cGVyLmdldFRl eHQoZWxlbWVu
dCk7CgkJfQoKCX0KCglwcml2YXRlIHN0YXRpYyBjbGFzcyBDb250ZW50UHJv dmlkZXIgaW1w
bGVtZW50cyBJU3RydWN0dXJlZENvbnRlbnRQcm92aWRlciB7CgkJcHJpdmF0 ZSBTdHJpbmdb
XSBhdHRyaWJ1dGVzOwoJCXByaXZhdGUgTGlzdDxJTWVkaWF0b3I+IG1lZGlh dG9ycyA9IG5l
dyBBcnJheUxpc3Q8SU1lZGlhdG9yPigpOwoKCQlwdWJsaWMgQ29udGVudFBy b3ZpZGVyKFN0
cmluZy4uLiBhdHRyaWJ1dGVzKSB7CgkJCXRoaXMuYXR0cmlidXRlcyA9IGF0 dHJpYnV0ZXM7
CgkJfQoKCQlwdWJsaWMgT2JqZWN0W10gZ2V0RWxlbWVudHMoT2JqZWN0IGlu cHV0RWxlbWVu
dCkgewoJCQlyZXR1cm4gbWVkaWF0b3JzLnRvQXJyYXkoKTsKCQl9CgoJCXB1 YmxpYyB2b2lk
IGRpc3Bvc2UoKSB7CgoJCX0KCgkJcHVibGljIHZvaWQgaW5wdXRDaGFuZ2Vk KFZpZXdlciB2
aWV3ZXIsIE9iamVjdCBvbGRJbnB1dCwgT2JqZWN0IG5ld0lucHV0KSB7CgkJ CW1lZGlhdG9y
cyA9IG5ldyBBcnJheUxpc3Q8SU1lZGlhdG9yPigpOwoKCQkJaWYgKG5ld0lu cHV0ICE9IG51
bGwgJiYgbmV3SW5wdXQgaW5zdGFuY2VvZiBMaXN0PD8+KSB7CgkJCQlmb3Ig KFN0cmluZyBh
dHRyaWJ1dGUgOiBhdHRyaWJ1dGVzKSB7CgkJCQkJbWVkaWF0b3JzLmFkZChu ZXcgTWVkaWF0
b3IoKExpc3Q8Pz4pIG5ld0lucHV0LCBhdHRyaWJ1dGUpKTsKCQkJCX0KCQkJ fQoJCX0KCX0K
Cglwcml2YXRlIHN0YXRpYyBjbGFzcyBFZGl0aW5nU3VwcG9ydEltcGwgZXh0 ZW5kcyBFZGl0
aW5nU3VwcG9ydCB7CgoJCXByaXZhdGUgaW50IGNvbEluZGV4OwoKCQlwcml2 YXRlIFRleHRD
ZWxsRWRpdG9yIGludGVnZXJFZGl0b3I7CgkJcHJpdmF0ZSBUZXh0Q2VsbEVk aXRvciBkYXRl
RWRpdG9yOwoKCQlwdWJsaWMgRWRpdGluZ1N1cHBvcnRJbXBsKENvbHVtblZp ZXdlciB2aWV3
ZXIsIGludCBjb2xJbmRleCkgewoJCQlzdXBlcih2aWV3ZXIpOwoJCQl0aGlz LmNvbEluZGV4
ID0gY29sSW5kZXg7CgkJCXRoaXMuaW50ZWdlckVkaXRvciA9IG5ldyBUZXh0 Q2VsbEVkaXRv
cigoQ29tcG9zaXRlKSB2aWV3ZXIKCQkJCQkuZ2V0Q29udHJvbCgpLCBTV1Qu Tk9ORSk7CgkJ
CSgoVGV4dCkgdGhpcy5pbnRlZ2VyRWRpdG9yLmdldENvbnRyb2woKSkKCQkJ CQkuYWRkVmVy
aWZ5TGlzdGVuZXIobmV3IFZlcmlmeUxpc3RlbmVyKCkgewoKCQkJCQkJcHVi bGljIHZvaWQg
dmVyaWZ5VGV4dChWZXJpZnlFdmVudCBlKSB7CgkJCQkJCQlTdHJpbmcgc3Ry aW5nID0gZS50
ZXh0OwoJCQkJCQkJY2hhcltdIGNoYXJzID0gbmV3IGNoYXJbc3RyaW5nLmxl bmd0aCgpXTsK
CQkJCQkJCXN0cmluZy5nZXRDaGFycygwLCBjaGFycy5sZW5ndGgsIGNoYXJz LCAwKTsKCQkJ
CQkJCWZvciAoaW50IGkgPSAwOyBpIDwgY2hhcnMubGVuZ3RoOyBpKyspIHsK CQkJCQkJCQlp
ZiAoISgnMCcgPD0gY2hhcnNbaV0gJiYgY2hhcnNbaV0gPD0gJzknKSkgewoJ CQkJCQkJCQll
LmRvaXQgPSBmYWxzZTsKCQkJCQkJCQkJcmV0dXJuOwoJCQkJCQkJCX0KCQkJ CQkJCX0KCQkJ
CQkJfQoJCQkJCX0pOwoJCQl0aGlzLmRhdGVFZGl0b3IgPSBuZXcgVGV4dENl bGxFZGl0b3Io
KENvbXBvc2l0ZSkgdmlld2VyCgkJCQkJLmdldENvbnRyb2woKSwgU1dULk5P TkUpOwoJCQko
KFRleHQpIHRoaXMuZGF0ZUVkaXRvci5nZXRDb250cm9sKCkpCgkJCQkJLmFk ZFZlcmlmeUxp
c3RlbmVyKG5ldyBWZXJpZnlMaXN0ZW5lcigpIHsKCgkJCQkJCXB1YmxpYyB2 b2lkIHZlcmlm
eVRleHQoVmVyaWZ5RXZlbnQgZSkgewoJCQkJCQkJU3RyaW5nIHN0cmluZyA9 IGUudGV4dDsK
CQkJCQkJCWNoYXJbXSBjaGFycyA9IG5ldyBjaGFyW3N0cmluZy5sZW5ndGgo KV07CgkJCQkJ
CQlzdHJpbmcuZ2V0Q2hhcnMoMCwgY2hhcnMubGVuZ3RoLCBjaGFycywgMCk7 CgkJCQkJCQlm
b3IgKGludCBpID0gMDsgaSA8IGNoYXJzLmxlbmd0aDsgaSsrKSB7CgkJCQkJ CQkJaWYgKCEo
ICgnMCcgPD0gY2hhcnNbaV0gJiYgY2hhcnNbaV0gPD0gJzknKSB8fCBjaGFy c1tpXSA9PSAn
LScgKSApIHsKCQkJCQkJCQkJZS5kb2l0ID0gZmFsc2U7CgkJCQkJCQkJCXJl dHVybjsKCQkJ
CQkJCQl9CgkJCQkJCQl9CgkJCQkJCX0KCQkJCQl9KTsKCQl9CgoJCUBPdmVy cmlkZQoJCXBy
b3RlY3RlZCBib29sZWFuIGNhbkVkaXQoT2JqZWN0IGVsZW1lbnQpIHsKCQkJ cmV0dXJuIHRy
dWU7CgkJfQoKCQlAT3ZlcnJpZGUKCQlwcm90ZWN0ZWQgQ2VsbEVkaXRvciBn ZXRDZWxsRWRp
dG9yKE9iamVjdCBlbGVtZW50KSB7CgkJCUlNZWRpYXRvciBtID0gKElNZWRp YXRvcikgZWxl
bWVudDsKCgkJCWlmIChtLmdldFR5cGUoY29sSW5kZXgpID09IGludC5jbGFz cykgewoJCQkJ
cmV0dXJuIGludGVnZXJFZGl0b3I7CgkJCX0gZWxzZSBpZiAobS5nZXRUeXBl KGNvbEluZGV4
KSA9PSBEYXRlLmNsYXNzKSB7CgkJCQlyZXR1cm4gZGF0ZUVkaXRvcjsKCQkJ fQoKCQkJcmV0
dXJuIG51bGw7CgkJfQoKCQlAT3ZlcnJpZGUKCQlwcm90ZWN0ZWQgT2JqZWN0 IGdldFZhbHVl
KE9iamVjdCBlbGVtZW50KSB7CgkJCUlNZWRpYXRvciBtID0gKElNZWRpYXRv cikgZWxlbWVu
dDsKCgkJCWlmIChtLmdldFR5cGUoY29sSW5kZXgpID09IGludC5jbGFzcykg ewoJCQkJcmV0
dXJuIG0uZ2V0VmFsdWUoY29sSW5kZXgpICsgIiI7CgkJCX0gZWxzZSBpZiAo bS5nZXRUeXBl
KGNvbEluZGV4KSA9PSBEYXRlLmNsYXNzKSB7CgkJCQlyZXR1cm4gbmV3IFNp bXBsZURhdGVG
b3JtYXQoInl5eXktTU0tZGQiKS5mb3JtYXQobQoJCQkJCQkuZ2V0VmFsdWUo Y29sSW5kZXgp
KTsKCQkJfQoKCQkJcmV0dXJuIG51bGw7CgkJfQoKCQlAT3ZlcnJpZGUKCQlw cm90ZWN0ZWQg
dm9pZCBzZXRWYWx1ZShPYmplY3QgZWxlbWVudCwgT2JqZWN0IHZhbHVlKSB7 CgkJCUlNZWRp
YXRvciBtID0gKElNZWRpYXRvcikgZWxlbWVudDsKCgkJCWlmIChtLmdldFR5 cGUoY29sSW5k
ZXgpID09IGludC5jbGFzcykgewoJCQkJdHJ5IHsKCQkJCQltLnNldFZhbHVl KGNvbEluZGV4
LCBJbnRlZ2VyLnBhcnNlSW50KHZhbHVlLnRvU3RyaW5nKCkpKTsKCQkJCX0g Y2F0Y2ggKE51
bWJlckZvcm1hdEV4Y2VwdGlvbiBlKSB7CgkJCQkJZS5wcmludFN0YWNrVHJh Y2UoKTsKCQkJ
CX0KCgkJCX0gZWxzZSBpZiAobS5nZXRUeXBlKGNvbEluZGV4KSA9PSBEYXRl LmNsYXNzKSB7
CgkJCQl0cnkgewoJCQkJCW0uc2V0VmFsdWUoY29sSW5kZXgsIG5ldyBTaW1w bGVEYXRlRm9y
bWF0KCJ5eXl5LU1NLWRkIikKCQkJCQkJCS5wYXJzZSh2YWx1ZS50b1N0cmlu ZygpKSk7CgkJ
CQl9IGNhdGNoIChQYXJzZUV4Y2VwdGlvbiBlKSB7CgkJCQkJZS5wcmludFN0 YWNrVHJhY2Uo
KTsKCQkJCX0KCQkJfQoJCQkKCQkJZ2V0Vmlld2VyKCkudXBkYXRlKGVsZW1l bnQsIG51bGwp
OwoJCX0KCX0KCglwdWJsaWMgc3RhdGljIHZvaWQgbWFpbihTdHJpbmdbXSBh cmdzKSB7CgkJ
dHJ5IHsKCQkJZmluYWwgRGlzcGxheSBkaXNwbGF5ID0gbmV3IERpc3BsYXko KTsKCQkJU2hl
bGwgc2hlbGwgPSBuZXcgU2hlbGwoZGlzcGxheSk7CgkJCXNoZWxsLnNldExh eW91dChuZXcg
RmlsbExheW91dCgpKTsKCgkJCWZpbmFsIEltYWdlUmVnaXN0cnkgcmVnID0g bmV3IEltYWdl
UmVnaXN0cnkoZGlzcGxheSk7CgkJCXJlZy5wdXQoIklDT04iLCBJbWFnZURl c2NyaXB0b3Iu
Y3JlYXRlRnJvbUZpbGUoCgkJCQkJR3JpZFZpZXdlclNuaXBwZXQ2LmNsYXNz LCAidGhfdmVy
dGljYWwuZ2lmIikpOwoKCQkJR3JpZFRhYmxlVmlld2VyIHYgPSBuZXcgR3Jp ZFRhYmxlVmll
d2VyKHNoZWxsLCBTV1QuRlVMTF9TRUxFQ1RJT04KCQkJCQl8IFNXVC5IX1ND Uk9MTCB8IFNX
VC5WX1NDUk9MTCk7CgkJCXYuZ2V0R3JpZCgpLnNldExpbmVzVmlzaWJsZSh0 cnVlKTsKCQkJ
di5nZXRHcmlkKCkuc2V0SGVhZGVyVmlzaWJsZSh0cnVlKTsKCQkJdi5zZXRD b250ZW50UHJv
dmlkZXIobmV3IENvbnRlbnRQcm92aWRlcigiYmlydGhkYXkiLCAiY29tbWl0 cyIsCgkJCQkJ
ImJ1Z3MiKSk7CgkJCXYuZ2V0R3JpZCgpLnNldFJvd0hlYWRlclZpc2libGUo dHJ1ZSk7CgkJ
CXYuc2V0Um93SGVhZGVyTGFiZWxQcm92aWRlcihuZXcgQ29sdW1uTGFiZWxQ cm92aWRlcigp
IHsKCQkJCUBPdmVycmlkZQoJCQkJcHVibGljIFN0cmluZyBnZXRUZXh0KE9i amVjdCBlbGVt
ZW50KSB7CgkJCQkJU3RyaW5nIHByb3BlcnR5TmFtZSA9ICgoTWVkaWF0b3Ip IGVsZW1lbnQp
CgkJCQkJCQkuZ2V0UHJvcGVydHlOYW1lKCk7CgkJCQkJcmV0dXJuIHByb3Bl cnR5TmFtZTsK
CQkJCX0KCgkJCX0pOwoKCQkJTGlzdDxDb21taXR0ZXI+IGNvbW1pdHRlcnMg PSBuZXcgQXJy
YXlMaXN0PENvbW1pdHRlcj4oKTsKCQkJY29tbWl0dGVycy5hZGQobmV3IENv bW1pdHRlcigi
VG9tIFNjaGluZGwiLCBuZXcgRGF0ZSgpLCAxMCwgNSkpOwoJCQljb21taXR0 ZXJzCgkJCQkJ
LmFkZChuZXcgQ29tbWl0dGVyKCJCb3JpcyBCb2tvd3NraSIsIG5ldyBEYXRl KCksIDEwMDAs
IDM1KSk7CgoJCQlpbnQgaSA9IDA7CgkJCWZvciAoQ29tbWl0dGVyIGNvbW1p dHRlciA6IGNv
bW1pdHRlcnMpIHsKCQkJCUdyaWRWaWV3ZXJDb2x1bW4gY29sdW1uID0gbmV3 IEdyaWRWaWV3
ZXJDb2x1bW4odiwgU1dULk5PTkUpOwoJCQkJY29sdW1uLnNldEVkaXRpbmdT dXBwb3J0KG5l
dyBFZGl0aW5nU3VwcG9ydEltcGwodiwgaSkpOwoJCQkJY29sdW1uLnNldExh YmVsUHJvdmlk
ZXIobmV3IExhYmVsUHJvdmlkZXJJbXBsKGkpKTsKCQkJCWNvbHVtbi5nZXRD b2x1bW4oKS5z
ZXRUZXh0KGNvbW1pdHRlci5nZXROYW1lKCkpOwoJCQkJY29sdW1uLmdldENv bHVtbigpLnNl
dFdpZHRoKDIwMCk7CgkJCQlpKys7CgkJCX0KCgkJCXYuc2V0SW5wdXQoY29t bWl0dGVycyk7
CgoJCQlzaGVsbC5zZXRTaXplKDUwMCwgMjAwKTsKCQkJc2hlbGwub3Blbigp OwoKCQkJd2hp
bGUgKCFzaGVsbC5pc0Rpc3Bvc2VkKCkpIHsKCQkJCWlmICghZGlzcGxheS5y ZWFkQW5kRGlz
cGF0Y2goKSkgewoJCQkJCWRpc3BsYXkuc2xlZXAoKTsKCQkJCX0KCQkJfQoK CQkJZGlzcGxh
eS5kaXNwb3NlKCk7CgkJfSBjYXRjaCAoRXhjZXB0aW9uIGUpIHsKCQkJZS5w cmludFN0YWNr
VHJhY2UoKTsKCQl9Cgl9Cgp9
--------------070401020909050409020601--
| Re: Row-wise table editing [message #64878 is a reply to message #64830] |
Fri, 19 June 2009 08:00  |
Thanks Tom,
This seems to be helpful in understanding the Column-Row transformation.
Mustufa
news:h1fqg3$brs$1@build.eclipse.org...
> Tom
>> Hi Tom,
>> to
>>> Hi,
>>> Tom
>>>> Hi Tom,
>>>> this
>>>> Rows,
>>>> by
>>>> APIs?
>>>> or
>>>> Columns
>>>> and
>>>> vice-versa.
>>>> Thanks
>>>> Mustufa
>>>>> Hi,
>>>>> you
>>>>> comes
>>>>> Tom
>>>>>> Hi,
>>>>>> Nebula
>>>>>> and
>>>>>> this
>>>>>> Thanks
>>>>>> Mustufa
> * Copyright (c) 2009 Tom Schindl and others.
> * All rights reserved. This program and the accompanying materials
> * are made available under the terms of the Eclipse Public License v1.0
> * which accompanies this distribution, and is available at
> * http://www.eclipse.org/legal/epl-v10.html
> * Contributors:
> * Tom Schindl - initial API and implementation
> package org.eclipse.swt.nebula.snippets.grid.viewer;
> import java.beans.BeanInfo;
> import java.beans.IntrospectionException;
> import java.beans.Introspector;
> import java.beans.PropertyDescriptor;
> import java.text.NumberFormat;
> import java.text.ParseException;
> import java.text.SimpleDateFormat;
> import java.util.ArrayList;
> import java.util.Date;
> import java.util.List;
> import org.eclipse.jface.resource.ImageDescriptor;
> import org.eclipse.jface.resource.ImageRegistry;
> import org.eclipse.jface.viewers.CellEditor;
> import org.eclipse.jface.viewers.ColumnLabelProvider;
> import org.eclipse.jface.viewers.ColumnViewer;
> import org.eclipse.jface.viewers.EditingSupport;
> import org.eclipse.jface.viewers.IStructuredContentProvider;
> import org.eclipse.jface.viewers.TextCellEditor;
> import org.eclipse.jface.viewers.Viewer;
> import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
> import org.eclipse.nebula.jface.gridviewer.GridViewerColumn;
> import org.eclipse.swt.SWT;
> import org.eclipse.swt.events.VerifyEvent;
> import org.eclipse.swt.events.VerifyListener;
> import org.eclipse.swt.layout.FillLayout;
> import org.eclipse.swt.widgets.Composite;
> import org.eclipse.swt.widgets.Display;
> import org.eclipse.swt.widgets.Shell;
> import org.eclipse.swt.widgets.Text;
> * Creating a viewer where columns are dynamic
> * @author Tom Schindl <tom.schindl@bestsolution.at>
> public class GridViewerSnippet7 {
> private static class Committer {
> private String name;
> private Date birthday;
> private int commits;
> private int bugs;
> public Committer(String name, Date birthday, int commits, int bugs) {
> this.name = name;
> this.birthday = birthday;
> this.commits = commits;
> this.bugs = bugs;
> public String getName() {
> return name;
> @SuppressWarnings("unused")
> public void setName(String name) {
> this.name = name;
> public int getCommits() {
> return commits;
> public void setCommits(int commits) {
> public int getBugs() {
> return bugs;
> public void setBugs(int bugs) {
> this.bugs = bugs;
> public Date getBirthday() {
> return birthday;
> public void setBirthday(Date birthday) {
> private static interface IMediator {
> public Object getValue(int index);
> public void setValue(int index, Object value);
> public Class<?> getType(int index);
> public String getPropertyName();
> private static class Mediator implements IMediator {
> private List<Object> domainObjects;
> private String propertyName;
> private PropertyDescriptor descriptor;
> public Mediator(List<?> domainObjects, String propertyName) {
> this.domainObjects = new ArrayList<Object>(domainObjects);
> this.propertyName = propertyName;
> BeanInfo beanInfo;
> try {
> beanInfo = Introspector.getBeanInfo(domainObjects.get(0)
> .getClass());
> PropertyDescriptor[] propertyDescriptors = beanInfo
> .getPropertyDescriptors();
> for (int i = 0; i < propertyDescriptors.length; i++) {
> PropertyDescriptor descriptor = propertyDescriptors[i];
> if (descriptor.getName().equals(propertyName)) {
> this.descriptor = descriptor;
> break;
> } catch (IntrospectionException e) {
> e.printStackTrace();
> public Object getValue(int index) {
> try {
> if (domainObjects.size() > index) {
> return descriptor.getReadMethod().invoke(
> domainObjects.get(index), new Object[0]);
> } catch (Exception e) {
> return null;
> public void setValue(int index, Object value) {
> try {
> descriptor.getWriteMethod().invoke(
> domainObjects.get(index), value);
> public Class<?> getType(int index) {
> return descriptor.getPropertyType();
> public String getPropertyName() {
> return propertyName;
> private static class LabelProviderImpl extends ColumnLabelProvider {
> private int colIndex;
> public LabelProviderImpl(int colIndex) {
> this.colIndex = colIndex;
> @Override
> public String getText(Object element) {
> IMediator m = (IMediator) element;
> if (m.getType(colIndex) == int.class) {
> return NumberFormat.getIntegerInstance().format(
> m.getValue(colIndex));
> } else if (m.getType(colIndex) == Date.class) {
> return new SimpleDateFormat("yyyy-MM-dd").format(
> return super.getText(element);
> private static class ContentProvider implements IStructuredContentProvider
> private String[] attributes;
> private List<IMediator> mediators = new ArrayList<IMediator>();
> public ContentProvider(String... attributes) {
> this.attributes = attributes;
> public Object[] getElements(Object inputElement) {
> return mediators.toArray();
> public void dispose() {
> public void inputChanged(Viewer viewer, Object oldInput, Object newInput)
> if (newInput != null && newInput instanceof List<?>) {
> for (String attribute : attributes) {
> mediators.add(new Mediator((List<?>) newInput, attribute));
> private static class EditingSupportImpl extends EditingSupport {
> private TextCellEditor integerEditor;
> private TextCellEditor dateEditor;
> public EditingSupportImpl(ColumnViewer viewer, int colIndex) {
> super(viewer);
> this.integerEditor = new TextCellEditor((Composite) viewer
> .getControl(), SWT.NONE);
> ((Text) this.integerEditor.getControl())
> .addVerifyListener(new VerifyListener() {
> public void verifyText(VerifyEvent e) {
> String string = e.text;
> char[] chars = new char[string.length()];
> string.getChars(0, chars.length, chars, 0);
> for (int i = 0; i < chars.length; i++) {
> if (!('0' <= chars[i] && chars[i] <= '9')) {
> e.doit = false;
> return;
> this.dateEditor = new TextCellEditor((Composite) viewer
> ((Text) this.dateEditor.getControl())
> if (!( ('0' <= chars[i] && chars[i] <= '9') || chars[i] == '-' ) ) {
> e.doit = false;
> return;
> @Override
> protected boolean canEdit(Object element) {
> return true;
> @Override
> protected CellEditor getCellEditor(Object element) {
> return integerEditor;
> return dateEditor;
> return null;
> @Override
> protected Object getValue(Object element) {
> return m.getValue(colIndex) + "";
> return new SimpleDateFormat("yyyy-MM-dd").format(m
> return null;
> @Override
> protected void setValue(Object element, Object value) {
> try {
> m.setValue(colIndex, Integer.parseInt(value.toString()));
> } catch (NumberFormatException e) {
> try {
> m.setValue(colIndex, new SimpleDateFormat("yyyy-MM-dd")
> .parse(value.toString()));
> } catch (ParseException e) {
> getViewer().update(element, null);
> public static void main(String[] args) {
> try {
> final Display display = new Display();
> Shell shell = new Shell(display);
> shell.setLayout(new FillLayout());
> final ImageRegistry reg = new ImageRegistry(display);
> reg.put("ICON", ImageDescriptor.createFromFile(
> GridViewerSnippet6.class, "th_vertical.gif"));
> GridTableViewer v = new GridTableViewer(shell, SWT.FULL_SELECTION
> | SWT.H_SCROLL | SWT.V_SCROLL);
> v.getGrid().setLinesVisible(true);
> v.getGrid().setHeaderVisible(true);
> v.setContentProvider(new ContentProvider("birthday", "commits",
> "bugs"));
> v.getGrid().setRowHeaderVisible(true);
> v.setRowHeaderLabelProvider(new ColumnLabelProvider() {
> @Override
> String propertyName = ((Mediator) element)
> .getPropertyName();
> List<Committer> committers = new ArrayList<Committer>();
> committers.add(new Committer("Tom Schindl", new Date(), 10, 5));
> committers
> .add(new Committer("Boris Bokowski", new Date(), 1000, 35));
> int i = 0;
> for (Committer committer : committers) {
> GridViewerColumn column = new GridViewerColumn(v, SWT.NONE);
> column.setEditingSupport(new EditingSupportImpl(v, i));
> column.setLabelProvider(new LabelProviderImpl(i));
> column.getColumn().setText(committer.getName());
> column.getColumn().setWidth(200);
> i++;
> v.setInput(committers);
> shell.setSize(500, 200);
> shell.open();
> while (!shell.isDisposed()) {
> if (!display.readAndDispatch()) {
> display.sleep();
> display.dispose();
| Re: Row-wise table editing [message #595230 is a reply to message #64712] |
Fri, 19 June 2009 04:25  |
Tom
> Thanks
> Mustufa
| Re: Row-wise table editing [message #595242 is a reply to message #64736] |
Fri, 19 June 2009 04:36  |
Hi Tom,
Thanks for the reply. Yes i did went through the idea you provided in this
Columns rather than rows. Is that possible using the inbuild JFace APIs? or
Consider a normal Nebula Grid editor but Rows will take place of Columns and
vice-versa.
Mustufa
> Tom
>> this
>> Thanks
>> Mustufa
| Re: Row-wise table editing [message #595248 is a reply to message #64758] |
Fri, 19 June 2009 04:51  |
Tom
> Hi Tom,
> vice-versa.
> Thanks
> Mustufa
>> Tom
>>> Hi,
>>> this
>>> Thanks
>>> Mustufa
| Re: Row-wise table editing [message #595265 is a reply to message #64781] |
Hi Tom,
> Tom
>> Hi Tom,
>> this
>> or
>> and
>> vice-versa.
>> Thanks
>> Mustufa
>>> Hi,
>>> Tom
>>>> Hi,
>>>> Nebula
>>>> this
>>>> Thanks
>>>> Mustufa
| Re: Row-wise table editing [message #595274 is a reply to message #64804] |
Tom
> Hi Tom,
>> Tom
>>> Hi Tom,
>>> this
>>> or
>>> and
>>> vice-versa.
>>> Thanks
>>> Mustufa
>>>> Hi,
>>>> Tom
>>>>> Hi,
>>>>> Nebula
>>>>> this
>>>>> Thanks
>>>>> Mustufa
| Re: Row-wise table editing [message #595307 is a reply to message #64830] |
Thanks Tom,
Mustufa
> Tom
>> Hi Tom,
>> to
>>> Hi,
>>> Tom
>>>> Hi Tom,
>>>> this
>>>> Rows,
>>>> by
>>>> APIs?
>>>> or
>>>> Columns
>>>> and
>>>> vice-versa.
>>>> Thanks
>>>> Mustufa
>>>>> Hi,
>>>>> you
>>>>> comes
>>>>> Tom
>>>>>> Hi,
>>>>>> Nebula
>>>>>> and
>>>>>> this
>>>>>> Thanks
>>>>>> Mustufa
> * Contributors:
> private int bugs;
> this.name = name;
> this.bugs = bugs;
> return name;
> this.name = name;
> return commits;
> return bugs;
> this.bugs = bugs;
> return birthday;
> BeanInfo beanInfo;
> try {
> .getClass());
> break;
> try {
> return null;
> try {
> @Override
> super(viewer);
> e.doit = false;
> return;
> e.doit = false;
> return;
> @Override
> return true;
> @Override
> return dateEditor;
> return null;
> @Override
> return null;
> @Override
> try {
> try {
> try {
> "bugs"));
> @Override
> .getPropertyName();
> committers
> int i = 0;
> i++;
> shell.open();
> display.sleep();
> display.dispose();
Current Time: Tue Nov 25 21:43:39 EST 2025
Powered by FUDForum. Page generated in 0.07272 seconds
