Home » Language IDEs » Java Development Tools (JDT) » Can Eclipse Debugger Log!
Can Eclipse Debugger Log! [message #64701] |
Sun, 22 June 2003 18:31  |
Originally posted by: vnssoftware.myway.com
Can Eclipse Debugger log each line (or method) it executes between two
breakpoints?
Thanks..
Re: Can Eclipse Debugger Log - - Why not?! [message #66808 is a reply to message #66500] |
Wed, 25 June 2003 05:13   |
Originally posted by: scheglov_ke.nlmk.ru
vns <vnssoftware@myway.com> wrote:
> I am looking for source code level tracing by the Debugger. Now -
> 1. Suppose there are 20 lines of code between two break points. Can it log
> these if we just resume execution from 1st breakpoint and let it go to 2nd
> breakpoint.
> 2. Can it at least log each line which is manually step over between two
> breakpoints. That is not what I am looking for though, but can it be made
> to do this.
> If the debugger cannot do both these, why- it anyway step overs when
> developer
> steps over.
Well, I think, that debugger have enough information to implement this
feature, may be this will work not very fast, but it will. But it seams,
that nobody else wants this, so you should implement this yourself. :-)
Profiler also could trace not only enter/leave in method, but also
for each line, but I don't have time to implement this.
SY, Konstantin.
Re: Can Eclipse Debugger Log - - Why not?! [message #67377 is a reply to message #66808] |
Wed, 25 June 2003 09:19   |
> > breakpoint.
> > to do this.
> > developer
> > steps over.
> for each line, but I don\'t have time to implement this.
> SY, Konstantin.
I wish I could take up this. But I am 100% Java only. I guess you require
C skills for this?
Thanks for the encouragement...
Re: Can Eclipse Debugger Log - - Why not?! [message #67397 is a reply to message #67377] |
Wed, 25 June 2003 09:31   |
log
2nd
> > > breakpoint.
> > > to do this.
> > > developer
> > > steps over.
> > SY, Konstantin.
> C skills for this?
ALso, I really don't understand why they don't want this. It can really
save time in 5000 Java files- you don't have to think where to set
Breakpoint soooo much.
Thanks..
Re: Can Eclipse Debugger Log - - Why not?! [message #67819 is a reply to message #67377] |
Wed, 25 June 2003 23:42   |
> C skills for this?
In both cases - profiler and Eclipse you need only hava knowledge.
For profiler you will use BCEL to parse class files and change bytecode.
For Eclipse (I am not sure, just guess) you will use debugger interface
to call commands like "step over" and "step into".
SY, Konstantin.
Re: Can Eclipse Debugger Log - - Why not?! [message #68334 is a reply to message #67819] |
Thu, 26 June 2003 14:25  |
> > C skills for this?
> SY, Konstantin.
That's good to know. If its only Java, I will give it a try:-)
Current Time: Tue Jul 22 01:32:59 EDT 2025
Powered by FUDForum. Page generated in 0.05018 seconds
