Problems when using xtextEditor which in a MultiPageEditor [message #643720] |
Wed, 08 December 2010 01:17 |
nma Messages: 18 Registered: July 2009 |
Junior Member |
I have added the xtextEditor in the MultiPageEditor, and got two kinds of exception.
The first one, while save the xtextEditor, there is:
2010-12-07 16:47:05,323 ERROR org.eclipse.xtext.ui.editor.folding.DefaultFoldingRegionProv ider - org.eclipse.jface.text.BadLocationException
and the saving function is OK, but report a lot of this exception.
The second one, is when I close the multiPageEditor, there is :
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench.texteditor".
at org.eclipse.jface.text.source.CompositeRuler$CompositeRulerC anvas.childRemoved(CompositeRuler.java:340)
at org.eclipse.jface.text.source.CompositeRuler.removeDecorator (CompositeRuler.java:590)
at org.eclipse.ui.texteditor.AbstractTextEditor$12.run(Abstract TextEditor.java:1735)
at org.eclipse.ui.texteditor.AbstractTextEditor$ColumnSupport.r emoveColumn(AbstractTextEditor.java:1739)
at org.eclipse.ui.texteditor.AbstractTextEditor$ColumnSupport.d ispose(AbstractTextEditor.java:1834)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor$2.disp ose(AbstractDecoratedTextEditor.java:771)
at org.eclipse.ui.texteditor.AbstractTextEditor.dispose(Abstrac tTextEditor.java:4308)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.dispos e(AbstractDecoratedTextEditor.java:368)
at org.eclipse.ui.editors.text.TextEditor.dispose(TextEditor.ja va:93)
at org.eclipse.xtext.ui.editor.XtextEditor.dispose(XtextEditor. java:383)
at org.eclipse.ui.part.MultiPageEditorPart$9.run(MultiPageEdito rPart.java:1002)
at org.eclipse.ui.part.MultiPageEditorPart.disposePart(MultiPag eEditorPart.java:999)
at org.eclipse.ui.part.MultiPageEditorPart.dispose(MultiPageEdi torPart.java:494)
and I still go no idea about this one.
Could you please help me about the two errors up?
Thank you very very much.
Regards.
Ma Ning
2010-12-8
FUDForum. Page generated in 0.02951 seconds
