derivation from existing Java classes [message #64682] |
Thu, 20 October 2005 03:52  |
if I understood well, the generated classes are notifiers, but they aren`t
adapters.
I would like them to derive from an adapter class.
As simpleType it could look like this:
<xsd:simpleType ecore:name="AnotherAdapter"
ecore:instanceClass="org.eclipse.emf.common.notify.impl.AdapterImpl ">
<xsd:restriction/>
</xsd:simpleType>
But as it is not possible to derive from a simpleType, that doesn`t work.
The only thing which comes in my mind is to have an adapter as instance in
the specified objects.
Is there another possibility to derive objects from existing Java classes?
Thanks for help in advance.
Re: derivation from existing Java classes [message #64726 is a reply to message #64705] |
Thu, 20 October 2005 06:31  |
OK, that helps me already.
Thanks a lot.
Ed Merks wrote:
> Enrique,
> You can mix in your own interfaces and can add your own methods into the
> generated code so I'm not sure you should be trying to model this in the
> schema. After all, will you be able to convert your adapter instance to
> and from a string representation? This is how you can extend additional
> interfaces by hand:
> import org.eclipse.emf.common.util.Enumerator;
> * <!-- begin-user-doc -->
> * A representation of the model object '<em><b>EEnum Literal</b></em>'.
> * @extends Enumerator
> * <!-- end-user-doc -->
> * <p>
> * The following features are supported:
> * <ul>
> * <li>{@link org.eclipse.emf.ecore.EEnumLiteral#getValue
> <em>Value</em>}</li>
> * <li>{@link org.eclipse.emf.ecore.EEnumLiteral#getInstance
> <em>Instance</em>}</li>
> * <li>{@link org.eclipse.emf.ecore.EEnumLiteral#getEEnum
> <em>EEnum</em>}</li>
> * </ul>
> * </p>
> * @see org.eclipse.emf.ecore.EcorePackage#getEEnumLiteral()
> * @model
> * @generated
> public interface EEnumLiteral extends ENamedElement, Enumerator
> As part of 93194 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=93194>
> I am looking into extending the annotation syntax so that things like
> EOperations and multiple inheritance are expressible directly in the
> schema (to try to make Ecore -> XSD -> Ecore a round trip).
> Enrique wrote:
>> aren`t adapters.
>> <xsd:restriction/>
>> </xsd:simpleType>
>> instance in the specified objects.
>> classes? Thanks for help in advance.
Re: derivation from existing Java classes [message #597037 is a reply to message #64682] |
Thu, 20 October 2005 05:42  |
--------------070604030007060606040509
Enrique,
interfaces by hand:
* <p>
* <ul>
* </ul>
* </p>
* @model
* @generated
Enrique wrote:
> aren`t adapters.
> <xsd:restriction/>
> </xsd:simpleType>
<html>
<head>
http-equiv="Content-Type">
</head>
Enrique,<br>
<br>
the generated code so I'm not sure you should be trying to model this
in the schema.
Re: derivation from existing Java classes [message #597049 is a reply to message #64705] |
Thanks a lot.
Ed Merks wrote:
> Enrique,
> interfaces by hand:
> * <p>
> * <ul>
> * </ul>
> * </p>
> * @model
> * @generated
> Enrique wrote:
>> aren`t adapters.
>> <xsd:restriction/>
>> </xsd:simpleType>
FUDForum. Page generated in 0.03239 seconds
