Home » Archived » XML Schema Definition (XSD) » derivation from existing Java classes
derivation from existing Java classes [message #64682] Thu, 20 October 2005 03:52 Go to next message
if I understood well, the generated classes are notifiers, but they aren`t
adapters.
I would like them to derive from an adapter class.
As simpleType it could look like this:
<xsd:simpleType ecore:name="AnotherAdapter"
ecore:instanceClass="org.eclipse.emf.common.notify.impl.AdapterImpl ">
<xsd:restriction/>
</xsd:simpleType>
But as it is not possible to derive from a simpleType, that doesn`t work.
The only thing which comes in my mind is to have an adapter as instance in
the specified objects.
Is there another possibility to derive objects from existing Java classes?
Thanks for help in advance.
Re: derivation from existing Java classes [message #64705 is a reply to message #64682] Thu, 20 October 2005 05:42 Go to previous messageGo to next message
--------------070604030007060606040509
Enrique,
You can mix in your own interfaces and can add your own methods into the
generated code so I'm not sure you should be trying to model this in the
schema. After all, will you be able to convert your adapter instance to
and from a string representation? This is how you can extend additional
interfaces by hand:
import org.eclipse.emf.common.util.Enumerator;
* <!-- begin-user-doc -->
* A representation of the model object '<em><b>EEnum Literal</b></em>'.
* @extends Enumerator
* <!-- end-user-doc -->
* <p>
* The following features are supported:
* <ul>
* <li>{@link org.eclipse.emf.ecore.EEnumLiteral#getValue
<em>Value</em>}</li>
* <li>{@link org.eclipse.emf.ecore.EEnumLiteral#getInstance
<em>Instance</em>}</li>
* <li>{@link org.eclipse.emf.ecore.EEnumLiteral#getEEnum
<em>EEnum</em>}</li>
* </ul>
* </p>
* @see org.eclipse.emf.ecore.EcorePackage#getEEnumLiteral()
* @model
* @generated
public interface EEnumLiteral extends ENamedElement, Enumerator
As part of 93194 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=93194>
I am looking into extending the annotation syntax so that things like
EOperations and multiple inheritance are expressible directly in the
schema (to try to make Ecore -> XSD -> Ecore a round trip).
Enrique wrote:
> aren`t adapters.
> <xsd:restriction/>
> </xsd:simpleType>
> instance in the specified objects.
> classes? Thanks for help in advance.
<html>
<head>
http-equiv="Content-Type">
</head>
Enrique,<br>
<br>
the generated code so I'm not sure you should be trying to model this
in the schema.
Re: derivation from existing Java classes [message #64726 is a reply to message #64705] Thu, 20 October 2005 06:31 Go to previous message
OK, that helps me already.
Thanks a lot.
Ed Merks wrote:
> Enrique,
> interfaces by hand:
> * <p>
> * <ul>
> * </ul>
> * </p>
> * @model
> * @generated
> Enrique wrote:
>> aren`t adapters.
>> <xsd:restriction/>
>> </xsd:simpleType>
Re: derivation from existing Java classes [message #597037 is a reply to message #64682] Thu, 20 October 2005 05:42 Go to previous message
Enrique,
interfaces by hand:
* <p>
* <ul>
* </ul>
* </p>
* @model
* @generated
Enrique wrote:
> aren`t adapters.
> <xsd:restriction/>
> </xsd:simpleType>
<html>
<head>
</head>
Enrique,<br>
<br>
in the schema.
Re: derivation from existing Java classes [message #597049 is a reply to message #64705] Thu, 20 October 2005 06:31 Go to previous message
Thanks a lot.
Ed Merks wrote:
> Enrique,
> interfaces by hand:
> * <p>
> * <ul>
> * </ul>
> * </p>
> * @model
> * @generated
> Enrique wrote:
>> aren`t adapters.
>> <xsd:restriction/>
>> </xsd:simpleType>
Previous Topic:derivation from existing Java classes
Next Topic:"unique" support
Current Time: Mon Jul 28 23:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.04566 seconds
