Re: Target Platform plugin dependent on workspace plugin [message #5826 is a reply to message #5810] |
Thu, 05 June 2008 14:49  |
Originally posted by: chopkins.cra.com
I was actually chasing a red herring so this didn't end up being an issue.
The original problem that I thought was happening is that a Target Platform
plugin specified a dependency on a package that was contributed by a
workspace plugin. It turns out the workspace plugin should have been a
Target Platform plugin. However, is that typically something that can
happen...a package dependency in a Target Platform where the package is
provided by a workspace plugin. I don't think that extension points help in
this situation as I understand them (admittedly, I may not understand them)
Is that more clear?
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g29an2$6d2$1@build.eclipse.org...
> Christopher Hopkins wrote:
>> Is it possible for a Target Platform plugin to be dependent on a
>> workspace plugin? I know the other way around works but I suspect that we
>> can't achieve this.
> Generally speaking, the mechanism to achieve this kind of thing is
> extension points. Any plugin can implement an extension for an extension
> point declared by a target platform plugin, thus introducing a runtime
> relationship between the target platform and the extending plugin.
> Does that help you? Do you control the target platform enough to add an
> extension point to one of its plugins?
> Eric
Re: Target Platform plugin dependent on workspace plugin [message #568218 is a reply to message #5793] |
Thu, 05 June 2008 14:20  |
> Is it possible for a Target Platform plugin to be dependent on a workspace
> plugin? I know the other way around works but I suspect that we can't
> achieve this.
Eric
Re: Target Platform plugin dependent on workspace plugin [message #568252 is a reply to message #5810] |
Is that more clear?
>> can't achieve this.
> Eric
FUDForum. Page generated in 0.08688 seconds
