Re: ContentAssist - CodeCompletion with Templates for Function-Parameters [message #642680 is a reply to message #642500] |
Thu, 02 December 2010 10:09 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Julian,
Xtext supports somewhat limited placeholders in content proposals out of
the box. Please have a look at
TerminalsProposalProvider#createStringProposal and digg into
ConfigurableCompletionProposal#setSimpleLinkedMode. However, multiple
linked fields in your proposal are not supported out of the box and
you'll have to implement that on your own.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 01.12.10 16:41, schrieb Julian:
> Hello,
> I include a model of different functions to my DSL with the import-URI
> mechanism.
> The CodeCompletion works so far. I get a Proposal list with all modelled
> functions + parameters and additional Information.
> I did this in the {DSL}ProposalProvider as mentioned in the
> xText-Documentation.
> If I choose one Proposal from the list, the proposal will be inserted.
> Like:
> .. Testfunction (int para1, int para2) ...
> What I want to achieve now is, that there are placeholders for the
> parameters, so that I can enter one an switch to the other one with a
> tab. As is known from the JavaIDE when I insert a function.
> At which point I have to start??
> The get the information for the proposal from a List with all functions.
> The functions createProposal and createAdditionalInformation just build
> a String from the information.
> part of my ProposalProvider
> for (int j=0; j < functions.size(); j++) {
> String proposal = pu.createProposal(functions.get(j));
> String additionalInformation =
> pu.createAdditionalInformation(functions.get(j));
> ICompletionProposal prop = createCompletionProposal(proposal, context);
> ConfigurableCompletionProposal confp = (ConfigurableCompletionProposal)
> prop;
> confp.setAdditionalProposalInfo(additionalInformation);
> acceptor.accept(prop);
> Julian
FUDForum. Page generated in 0.04902 seconds
