Home » Eclipse Projects » Nebula » help about gallery
help about gallery [message #64576] Tue, 16 June 2009 15:30 Go to next message
Hi:
i am using the gallery and the expansion and redraw process are very slow,
could you help me ?
The attached code pick up photos from a folder. Thank you very much
Greetings.
import java.io.File;
import java.util.Arrays;
import org.eclipse.nebula.widgets.gallery.Gallery;
import org.eclipse.nebula.widgets.gallery.GalleryItem;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
public class prueba {
static int indentLevel=-1;
static Gallery list ;
static Shell shell;
public static void main (String [] args) {
Display display = new Display ();
shell = new Shell (display);
FillLayout fillLayout = new FillLayout ();
shell.setLayout (fillLayout);
list = new Gallery (shell, SWT.BORDER|SWT.MULTI );
list.setLowQualityOnUserAction(true);
list.setAntialias(SWT.ON);
list.setInterpolation(SWT.LOW);
shell.open ();
listPath(new File("C:\\FotosVeterinaria"));
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ())
display.sleep ();
display.dispose ();
public static void listPath(File path) {
File files[];
indentLevel++;
files = path.listFiles();
Arrays.sort(files);
Image nuevo;
GalleryItem group = new GalleryItem(list, SWT.VIRTUAL);
GalleryItem item ;
group.setText("Imagenes");
group.setExpanded(true);
Display display = shell.getDisplay();
for (int i = 0, n = files.length; i < n; i++) {
for (int indent = 0; indent < indentLevel; indent++) {
System.out.print(" *** ");
if (files[i].toString().contains(".JPG")) {
item = new GalleryItem(group, SWT.NONE);
nuevo = new Image(display,files[i].toString() );
item.setImage(nuevo);
// item.setText(files[i].toString());
// item.setData(files[i].toString());
indentLevel--;
Re: help about gallery [message #64920 is a reply to message #64576] Sun, 21 June 2009 12:47 Go to previous message
Hi Gaston,
2 issues in you code :
- You didn't understand how the VIRTUAL flag works, your code doesn't
take benefit of it. Look at :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet202.java?view=co
- You are creating item with full-sized images. The gallery has to
resize each item for each redraw, by default with interpolation and
antialiasing. If some images are > than 640x400 this will slow the
redraws down. To fix this :
* Change resize quality : Gallery#setAntialias and
Gallery#setInterpolation.
* and/or Use Gallery#setLowQualityOnUserAction()
* and/or Resize images before calling GalleryItem#setImage()
Note that Linux / GTK is really slower than windows or mac osx when
drawing with interpolation and antialias. On this platform you ofter
need to reduce quality to get a decent speed.
See : http://wiki.eclipse.org/Nebula_Gallery_FAQ
I hope this will help you.
Nicolas
gaston a écrit :
> Hi:
> slow, could you help me ?
> Greetings.
> import org.eclipse.swt.widgets.Display;
> static Shell shell;
> shell.open ();
> display.sleep ();
> display.dispose ();
> File files[]; indentLevel++; files =
> path.listFiles();
> Arrays.sort(files);
> Image nuevo;
> GalleryItem item ;
> group.setText("Imagenes"); group.setExpanded(true);
> nuevo = new
> indentLevel--;
Re: help about gallery [message #595327 is a reply to message #64576] Sun, 21 June 2009 12:47 Go to previous message
Hi Gaston,
Nicolas
gaston a écrit :
> Hi:
> Greetings.
> static Shell shell;
> shell.open ();
> display.sleep ();
> display.dispose ();
> path.listFiles();
> Arrays.sort(files);
> Image nuevo;
> GalleryItem item ;
> nuevo = new
> indentLevel--;
Previous Topic:Row-wise table editing
Next Topic:Gantt: remove Connections
Current Time: Sat Jul 26 05:01:03 EDT 2025
Powered by FUDForum. Page generated in 0.04008 seconds
