Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build.properties
PDE build.properties [message #64560] Wed, 10 June 2009 09:35 Go to next message
I notice that PDE headless build behaves differently on Win and Linux.
On Linux, I have to specify this in my build.properties:
bootclasspath=${jre}/lib/rt.jar
otherwise it would not find any of java.lang.* classes.
I don't have to do that on Win. Does anyone know if there's something
missing I need to set for Linux? Thanks.
Re: PDE build.properties [message #64607 is a reply to message #64560] Wed, 10 June 2009 13:46 Go to previous message
If nothing is set, then the default bootclasspath is going to be
${java.home}/lib/*.jar
Ant provides access to all java system properties, here "java.home" was
expected to be set by your vm. Perhaps your vm on linux isn't setting
this property? (And setting "jre" instead?)
-Andrew
Re: PDE build.properties [message #598238 is a reply to message #64560] Wed, 10 June 2009 13:46 Go to previous message
-Andrew
Previous Topic:How to access external Resources (best practices wanted)
Next Topic:Target Pltatform Based On Update Site
Current Time: Sun Aug 31 12:54:51 EDT 2025
Powered by FUDForum. Page generated in 0.30107 seconds
