Home » Language IDEs » Java Development Tools (JDT) » Method line number
Method line number [message #64519] Sun, 22 June 2003 10:54 Go to next message
Originally posted by: pebraert.vub.ac.be
Is there really nobody with an answer for this issue?
I have the following:
- a methodName M
- a Path to a java-file J
I want to find the line number in J where M is defined. Can someone tell
me how to do that?
Re: Method line number [message #64655 is a reply to message #64519] Sun, 22 June 2003 13:27 Go to previous messageGo to next message
use the JavaCore APIs, something like this:
ICompilationUnit unit = JavaCore.create(path);
then get the types from it with getAllTypes(), and iterate over the methods
of those types (getMethods()) until you find the one you want and ask for
its source range with getSourceRange(). This gives the start and length of
the
source for the method. I recall there is a way to find the line number given
a source
range, but I can't find it right now. Hope this gets you started.
Frank
"Peter Ebraert" <pebraert@vub.ac.be> wrote in message
news:bd4fvt$pcs$1@rogue.oti.com...
> - a methodName M
> me how to do that?
Re: Method line number [message #65315 is a reply to message #64655] Mon, 23 June 2003 13:50 Go to previous messageGo to next message
Yep, indeed, now I got the offset of that method in that file.
So the only missing link is on how to get a line number for a offset and a
file. Somebody knows?
Peter
> the
> a source
> range, but I can\'t find it right now. Hope this gets you started.
> Frank
Re: Method line number [message #65379 is a reply to message #65315] Mon, 23 June 2003 14:15 Go to previous messageGo to next message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Mon, 23 Jun 2003 17:50:20 +0000 (UTC), pebraert@vub.ac.be (Peter
>Cheers,
>Peter
If you have a org.eclipse.jdt.core.dom.CompilationUnit in hand, then
you simply need to use the lineNumber(int) method using the start
position of your source range.
Does it work for you?
Olivier
Re: Method line number [message #65550 is a reply to message #65379] Mon, 23 June 2003 16:10 Go to previous message
Life can be sooo easy ;-)
All working now!
> Olivier
Previous Topic:Multiple entries in the "Open Type" dialog...
Next Topic:Stepping into JAVA API classes
Current Time: Sun Jul 06 18:32:40 EDT 2025
Powered by FUDForum. Page generated in 0.03344 seconds
