Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with TPTP 4.1 and 4.2 (IWAT4039E)
Problem with TPTP 4.1 and 4.2 (IWAT4039E) [message #64503] Wed, 05 April 2006 15:53 Go to next message
Originally posted by: thomas.olsson.in2objects.com
I have generated a test suit with the http recorder but when I try to run it
with RAC I get a:
!MESSAGE IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.core.runtime.CoreException
!STACK 1
org.eclipse.core.runtime.CoreException: IWAT4039E The Test Execution Harness
reported the following problems:java.net.ConnectException: Connection
refused:
connectorg.eclipse.hyades.internal.execution.core.file.Serve rNotAvailableException:
java.net.ConnectException: Connection refused: connect
org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:178)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:733)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:931)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!SUBENTRY 1 org.eclipse.hyades.test.core 4 0 2006-04-05 18:46:17.375
problems:java.net.ConnectException: Connection refused:
This I appearing after 66%.
I'm running against Weblogic Server with jsk 1.5.0_04.
I can connect and profile the server but not run the recording test
(generated junit test runs OK).
I've tried this both with TPTP 4.1 and the latest 4.2 release.
Has this to do with fact that I'm using jdk 5?
Is there any solution?
Many thanks
Thomas
Re: Problem with TPTP 4.1 and 4.2 (IWAT4039E) [message #65267 is a reply to message #64503] Mon, 10 April 2006 08:04 Go to previous messageGo to next message
Hi Thomas,
Test execution requires the Agent Controller's file server (port 10005,
by default) to deploy the test assets. Can you confirm that the Agent
Controller's file server is running on port 10005 and that this port is
free? You can check the filePort attribute on the
AgentControllerConfiguration element in the <Agent Controller's install
directory>/config/serviceconfig.xml. If 10005 is free, please try with JRE
V1.4.x. If the problem persists, please open a defect in TPTP's bugzilla.
Paul
"Thomas Olsson" <thomas.olsson@in2objects.com> wrote in message
news:e1178c$qav$1@utils.eclipse.org...
> Hi
it
> with RAC I get a:
> !STACK 1
Harness
> refused:
eption:
> at
egate2.launch(AbstractLaunchConfigurationDelegate2.java:178)
> at
on.java:590)
> at
on.java:515)
> at
a:733)
> at
eption:
> Many thanks
> Thomas
Re: Problem with TPTP 4.1 and 4.2 (IWAT4039E) [message #67168 is a reply to message #65267] Thu, 20 April 2006 05:30 Go to previous messageGo to next message
I got it to work!
The problem is that it takes 3 to 4 minutes to start the test, I don't know
what it does during that time (CPU is running at 100%). When it runs the
test
it only takes a second...
When it took that long time I thought it was something wrong and killed
Eclipse now I know it works but it takes so long for it to execute the test.
My machine is a 1.6 Ghz Pentium Mobile with 2 GB ram.
thomas
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:e1dhjm$1le$1@utils.eclipse.org...
> Hi Thomas,
> JRE
> Paul
>> Hi
> it
>> with RAC I get a:
>> !STACK 1
> Harness
>> refused:
> eption:
>> at
>> at
> on.java:590)
>> at
> on.java:515)
>> at
> a:733)
>> at
> eption:
>> Many thanks
>> Thomas
Re: Problem with TPTP 4.1 and 4.2 (IWAT4039E) [message #68644 is a reply to message #67168] Wed, 26 April 2006 08:41 Go to previous message
Hi Thomas,
Great news!
How big is your test suite (e.g. number of tests or HTTP requests)?
Paul
news:e27kcm$ka8$1@utils.eclipse.org...
> I got it to work!
know
> test
test.
> Thanks
> thomas
> > Hi Thomas,
10005,
> > JRE
bugzilla.
> > Paul
> >> Hi
run
> > it
> >> with RAC I get a:
> >> !STACK 1
> > Harness
> >> refused:
> > eption:
> >> at
> >> at
> > on.java:590)
> >> at
> > on.java:515)
> >> at
> > a:733)
> >> at
> >> at
> > eption:
> >> Many thanks
> >> Thomas
Previous Topic:Select items by name in AGR macro
Next Topic:TPTP Manual Test - Export to XL sheet ?
Current Time: Sun Aug 31 05:24:43 EDT 2025
Powered by FUDForum. Page generated in 0.03097 seconds
