Home » Modeling » GMF (Graphical Modeling Framework) » Diagram type-ing
Diagram type-ing [message #64452] Tue, 17 October 2006 12:17 Go to next message
Within GMF what is the correct import to use for "Diagram" to resolved?
Cheers
Re: Diagram type-ing [message #64499 is a reply to message #64452] Tue, 17 October 2006 12:24 Go to previous message
Originally posted by: vcciubot.uwaterloo.ca
Ctr-Shift-T and search for Diagram. Or ctrl-space as you declare a
variable such as Diagra<ctrl-space>
If it doesn't work, the approach suggested in
http://www.amazon.com/Eclipse-Building-Commercial-Quality-Pl ug-ins/dp/0321228472
is to create a dummy java project and add to its dependencies all the
plugins under /path to eclipse/eclipse/plugins
vlad
On Tue, 17 Oct 2006 16:17:33 +0000,
> Cheers
Previous Topic:Problems when using "Affixed Parent Side" property
Next Topic:Hide/Show Compartment Command
Current Time: Fri Sep 12 21:57:21 EDT 2025
Powered by FUDForum. Page generated in 0.02907 seconds
