Home » Language IDEs » AspectJ » AspectJ 1.5.1a and Eclipse 3.0
AspectJ 1.5.1a and Eclipse 3.0 [message #64444] Wed, 12 April 2006 11:29 Go to next message
As a number of people are still using Eclipse 3.0 (and based products), we
thought it'd be good to make the memory-reduced goodness of AspectJ
1.5.1a available in that environment. AJDT 1.2.1 already contains AspectJ
1.5.0, so we will do an AJDT 1.2.2 containing AspectJ 1.5.1a. In fact
development builds of this are now available:
http://www.eclipse.org/ajdt/downloads/#dev
The only changes specific to the AJDT side of things since AJDT 1.2.1 are
the changes necessary to support the newer version of AspectJ. We're
not planning any other changes. Please try out the latest development
build if you are using Eclipse 3.0 and report any bugs as usual. We will
then promote it to a release build in the next week or two.
Matt.
Re: AspectJ 1.5.1a and Eclipse 3.0 [message #64467 is a reply to message #64444] Thu, 13 April 2006 10:14 Go to previous message
Matt & Co.,
Thanks for this very quick effort.
I've been using this for a few days and it seems solid. I can tell that
the memory usage is improved. It might still be a bit high for our
application but it is definitely better.
For a "normal" application, after a full build (with -Xmx1350m), I'll hit
a peak of 1280M and then drop to 1150M. I just wish I had another 512M of
memory!
But I am using it and frankly RAD is causing no more problems than before.
Before the update, for the same workspace, I would often just start
trashing in the GC (I assume0 and sit building the same project for 10+
minutes before I'd just kill RAD. Now, I make it past the build but it
still takes quite a long time with the CPU at 100% for some time.
I'm going to keep working with it; overall it's a noticeable improvement.
Brett
Re: AspectJ 1.5.1a and Eclipse 3.0 [message #593423 is a reply to message #64444] Thu, 13 April 2006 10:14 Go to previous message
Matt & Co.,
memory!
Brett
Previous Topic:AspectJ 1.5.1a and Eclipse 3.0
Next Topic:Eclipse 3.2RC1
Current Time: Tue Jul 08 08:25:00 EDT 2025
Powered by FUDForum. Page generated in 2.43339 seconds
