Classloader issue with Eclipse [message #64427] |
Thu, 05 June 2003 15:11  |
I am doing a Transformation using Xalan in a plugin which is running on
JDK1.3.1_08. While creating new instance with TransformerFactory I am
getting the following error.
"javax.xml.transform.TransformerFactoryConfigurationError: Provider
org.apache.xalan.processor.TransformerFactoryImpl not found at
javax.xml.transform.TransformerFactory.newInstance(Unknown Source)"
in the line
TransformerFactory tFactory = TransformerFactory.newInstance();
The jar files are in classpath and there is no conflict. I even tried
setting the system properties. I disabled most of the plugins and running
with minimal plugins. I want to know is there anything in eclipse that is
conflicting with this setup. The same setup is working with JDK1.4.
Thanks in advance,
Dinesh
FUDForum. Page generated in 0.02592 seconds
