Home » Newcomers » Newcomers » Confused by the workspaces-concept
Confused by the workspaces-concept [message #64418] Sun, 15 May 2005 17:24 Go to next message
Originally posted by: jeroen.lightyear.be
I'm a bit confused by the workspaces. To my feeling there are two
possible uses for the workspaces so i'm not entirely sure which of those
two i should use, or maybe i don't understand the concept very well.
One possible use for a workspace is something to group projects that
belong together, similar like in Visual Studio.NET where you can create
'solutions' to group projects that belong together. So when using
workspaces this way i would create a new workspace for every new
'project' (application, website etc) i start. By example to clearly
seperate a project I do for school, from another project i do for fun.
However the problem with this approach is that every new workspace
starts with the default settings so I have to configure every new
workspace again so that it uses my preferred settings.
The other possible use is to see a workspace as a set of preferences.
With this approach i would just create one workspace with all my
preferences and add all my projects to it. However this would become a
mess if I have, say, 30 projects of which most are not related to each
other but some are. Somehow i would like to group the related projects.
(i tried to create a project inside a project but this seems not possible).
To summarize:
- When creating a workspace for every 'project' -> i have to reconfigure
every new workspace , how can i automatically use my preferred settings
in a new workspace (also when i change a setting it should change in all
the workspaces)?
- When using only one workspace -> how can i group projects that belong
together?
Thx for helping me!
Greetz,
Jeroen
Re: Confused by the workspaces-concept [message #64487 is a reply to message #64418] Sun, 15 May 2005 22:00 Go to previous messageGo to next message
Originally posted by: yally_l.126.com
You can use 'Working Set' in the Navigator view to group your projects
with one Workspace managing your preferences setting.
Re: Confused by the workspaces-concept [message #64510 is a reply to message #64487] Mon, 16 May 2005 03:30 Go to previous messageGo to next message
Nice! That's exactly what i was looking for :)
thx!
Jeroen
Re: Confused by the workspaces-concept [message #64623 is a reply to message #64510] Mon, 16 May 2005 09:21 Go to previous messageGo to next message
> thx!
> Jeroen
You can also use the Export/Import buttons on the Preference dialog to
save preferences from one workspace and import them into another.
Re: Confused by the workspaces-concept [message #64666 is a reply to message #64623] Mon, 16 May 2005 09:38 Go to previous messageGo to next message
I tried that but it didn't seem to work... (with Eclipse 3.1M6)
Re: Confused by the workspaces-concept [message #64782 is a reply to message #64510] Mon, 16 May 2005 11:05 Go to previous messageGo to next message
Working Sets are definitely your Friend.
Another tip is to close projects that you are not interested in.
Right-click a Project and choose Close Project - that will essentially
hide it from most functionality until you Open it again.
Also note that you can easily delete a project from your workspace. As
long as you choose the option to NOT delete the project contents (files
and directories), you can easily add it back again later when you want
to work on it again. IOW, deleting a project from the workbench without
deleting its contents is kind of like taking a book chapter out of the
table of contents but leaving the actual pages in place - it is still
there for future reference.
HTH,
Eric
Re: Confused by the workspaces-concept [message #64871 is a reply to message #64782] Mon, 16 May 2005 14:36 Go to previous message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I was aware of these two methods but prefer Working Sets. It's easier to
organize them :)
thx!
Greetz,
Jeroen
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCiOhJH04wF4t7d0oRAlagAJ0UxTs10QIrVCdJyOnnXE1JRUyelACf dSPm
OP5udoZywBAA/JN33JsnTFU=
=od87
-----END PGP SIGNATURE-----
Previous Topic:Viewing every constructors
Next Topic:eclipse debugging with tomcat - step filtering
Current Time: Thu Aug 21 15:12:04 EDT 2025
Powered by FUDForum. Page generated in 0.09400 seconds
