Home » Modeling » M2T (model-to-text transformation) » acceleo run configuration with model outside of workspace
acceleo run configuration with model outside of workspace [message #64370] Mon, 13 July 2009 17:10 Go to next message
I'm trying to setup my run configuration for the acceleo generation. If I
try to use a model that is in a project that is located outside of the
workspace if won't generate any files.
works fine:
<workspace>/foo/bar.uml
but if I wish to have my project in a different location, say perhaps I
want to check it out of version control, it doesn't work fine:
/svn/trunk/foo/bar.uml
Am I doing something wrong or Is this a bug, and is there a workaround?
/Mats Svefors
Re: acceleo run configuration with model outside of workspace [message #64693 is a reply to message #64370] Mon, 20 July 2009 05:13 Go to previous message
--------------000301030902000800040102
Hi Mats,
Sorry, I overlooked this post :(.
We haven't tried anything to enable the use of models located outside of
the workspace from these launch configurations. I believe we could make
it for models located on disk. Can you raise an enhancement request for
this? The use of repository models (svn, models, http, ...) will most
likely not be supported though.
Laurent Goubet
Obeo
Mats Svefors a
Previous Topic:[Announce] M2T XPAND 0.7.1 is available
Next Topic:Re: OAW to TMF migration: ext allElements migration
Current Time: Wed Sep 03 00:04:35 EDT 2025
Powered by FUDForum. Page generated in 0.06283 seconds
