Home » Language IDEs » C / C++ IDE (CDT) » Problems using CDT just for code browsing
Problems using CDT just for code browsing [message #64359] Tue, 11 March 2003 21:02 Go to next message
Originally posted by: ian._delete_kelman.com
I'm a Java developer who is only _browsing_ C++ code in a CVS repository. I
thought I'd give CDT a try since I'm already using Eclipse, but so far I'm
no better off with CDT than with a Resource perspective. I'm having two
problems: first, I can't use the C Editor for .h files because Eclipse is
hanging when I try to open one; and second, searching for references hardly
finds anything - I can't make sense of the search scope.
I have no compiler or build tools installed because I only want to browse
the code. Is there some minimal environment that I'm missing to do this?
I'm really hoping that browsing code would be nicer with CDT, and also
figuring I'd get a quick look at CDT and show it to the C++ developers here.
I've tried to install CDT 1.0.1 GA over Eclipse 2.0.2 on a Windows 2000
platform, but with no luck.
Ian Graham
Re: Problems using CDT just for code browsing [message #64382 is a reply to message #64359] Wed, 12 March 2003 16:30 Go to previous messageGo to next message
I did some more exploring and discovered the real problem. See Bugzilla
34869(http://dev.eclipse.org/bugs/show_bug.cgi?id=34869).
"Ian Graham" <ian@_delete_kelman.com> wrote in message
news:b4m4hu$q1f$1@rogue.oti.com...
I
hardly
here.
> Ian Graham
Re: Problems using CDT just for code browsing [message #64405 is a reply to message #64382] Thu, 13 March 2003 03:51 Go to previous message
Originally posted by: nospam.nospam.com
This may be unrelated but I get occasional hangs opening any sort of file in
a CDT project.
This is on linux and sometimes I see "fstat" messages in the console
appearing at the same time.
Chris
news:b4o8tn$dcd$1@rogue.oti.com...
repository.
> I
I'm
is
> hardly
browse
this?
> here.
> > Thanks,
> > Ian Graham
Previous Topic:CDT Newbie: How do I get the MakeView Resource?
Next Topic:!!HELP!! Errors in CDT after loading source in plugin projects
Current Time: Fri May 09 17:39:33 EDT 2025
Powered by FUDForum. Page generated in 0.13973 seconds
