Home » Language IDEs » PHP Development Tools (PDT) » syntax highlighting problem with include files
syntax highlighting problem with include files [message #64305] Tue, 08 January 2008 12:43 Go to next message
Originally posted by: amv.advalvas.Be
I installed the eclipse version 3.3.1.1 (europe) and I have a problem with
the syntax checking.
For example I use a header.php file where I put my head, title and start
body tags.
I also use a footer where i close my tags.
Problem is I get a whole bunch of errors about incomplete tags.
Is there a way around this.
I google some and found that jsp file have the similar problem but there
seems to be a workaround using jspf file (code fragment files).
Is there some way to to the same thing with php files.
I do not want to disable the syntax checking for all my files.
Annemie
Re: syntax highlighting problem with include files [message #64442 is a reply to message #64305] Fri, 11 January 2008 21:29 Go to previous message
Do you mean that disabling 'HTML Syntax Validator (for PHP Files)' in
Preferences->Validation doesn't satisfy your needs?
If you mean you want to avoid errors/warnings for some specific PHP files,
there are no such range for validation. (It is workspace-wide or
*project-wide*)
If you mean you want to avoid some specific errors/warnings such as 'No
end tag', there are no ways. You can only filter them out from Problems
View.
Previous Topic:Problems running PHP and HTML files
Next Topic:Download what files?
Current Time: Mon Jul 14 21:17:18 EDT 2025
Powered by FUDForum. Page generated in 0.03087 seconds
