CVS connection problem using Eclipse [message #64289] |
Thu, 05 June 2003 14:11  |
Originally posted by: removespam-les.carter.help-me.to
I can connect to my CVS repository using Eclipse 2.0.? when I'm using Win
XP, but when I switch over to my linux box (SuSE 8.0) using Eclipse 2.1,
even though I'm using the same connection details, I get an IO failure,
connection refused (even though I can telnet into the pserver). The SuSE
install has all current update patches applied.
Can anyone cast some light as to what might be going on?
Re: CVS connection problem using Eclipse [message #65304 is a reply to message #64289] |
Fri, 06 June 2003 06:29  |
Is this reproduceable? Is there anything in the .log file? Could you try
using extssh or ext and see if you can connect using one of those
connection methods?
Jean-Michel
FUDForum. Page generated in 0.27252 seconds
