Home » Eclipse Projects » Plugin Development Environment (PDE) » Not getting Instance of IResource
Not getting Instance of IResource [message #64283] Mon, 08 June 2009 09:44 Go to next message
Was just trying out some example. I want to create a trigger point at
instance of IResource. However when I declare this instance in the
plugin.xml I get error as "org.eclipse.core.resources.IResource" in
attribute "value" is not in the plug-in classpath.
below is the snippet of my xml
<triggerPoints>
<or>
<and>
<instanceof
value="org.eclipse.core.resources.IResource">
</instanceof>
<test
forcePluginActivation="true"
property="org.eclipse.core.resources.extension"
value="properties">
</test>
</and>
<instanceof
value="com.eclipse.ui.dagger.navigator.PropertiesTreeData">
</instanceof></or>
</triggerPoints>
Does this mean the IResource package is not available in my eclipse
installation?
Re: Not getting Instance of IResource [message #64306 is a reply to message #64283] Mon, 08 June 2009 09:59 Go to previous message
Got it.. Please Ignore
Re: Not getting Instance of IResource [message #598153 is a reply to message #64283] Mon, 08 June 2009 09:59 Go to previous message
Previous Topic:Not getting Instance of IResource
Next Topic:ClassNotFoundException when running Java application inside PDE project
Current Time: Sat Jul 26 13:58:05 EDT 2025
Powered by FUDForum. Page generated in 0.03572 seconds
