Home » Archived » Test and Performance Tools Platform (TPTP) » Installing Hyades Runtime 3.2.0 trashes Eclipse
Installing Hyades Runtime 3.2.0 trashes Eclipse [message #5754] Mon, 14 February 2005 09:25 Go to next message
Originally posted by: lars.ohlen_nospm.se
I noticed some strange side effect after installing Hyades 3.2.0
(hyades.runtime_3.2.0_20041221_1637)
After unzipping the package into my Eclipse installation the 'Product
Configuration' (Help->Software Updates->Manages Configuration)
is empty. This means that I no longer can configure my Eclipse instance.
Is there any way of fixing this?
BR
Lars
Re: Installing Hyades Runtime 3.2.0 trashes Eclipse [message #5790 is a reply to message #5754] Tue, 15 February 2005 10:04 Go to previous messageGo to next message
Originally posted by: jan.nicklisch.entimo.de
I've noticed that after unzipping the hyades distribution, file plugin.xml
in folder
\plugins\org.apache.jakarta_log4j_logging_1.2.8
has a non printable character at its first position; after removing that
character eclipse's update mechanism is able to parse that file correctly
(see error log from eclipse Help > About Eclipse Platform > Configuration
Details > View Error Log.
Good luck, man, struggling with open source ...
Jan Nicklisch
plugin.xml's first line:
Re: Installing Hyades Runtime 3.2.0 trashes Eclipse [message #5847 is a reply to message #5790] Wed, 16 February 2005 07:25 Go to previous messageGo to next message
Jan and Lars,
The Byte Order Mark (BOM) problem with the plugin.xml in the
\plugins\org.apache.jakarta_log4j_logging_1.2.8 plugin has since been fixed
under defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=82305.
Paul
"Jan Nicklisch" <jan.nicklisch@entimo.de> wrote in message
news:cut31t$bl7$1@www.eclipse.org...
> in folder
> Jan Nicklisch
Re: Installing Hyades Runtime 3.2.0 trashes Eclipse [message #6835 is a reply to message #5847] Fri, 18 February 2005 06:41 Go to previous messageGo to next message
Paul,
thanks for making this point clear; however, Lars, me and probably a few
others were having that hard time trying to install a release candidate from
December (still on the download page).
[Lars:] ... after installing Hyades 3.2.0
Re: Installing Hyades Runtime 3.2.0 trashes Eclipse [message #6849 is a reply to message #6835] Mon, 21 February 2005 07:14 Go to previous message
Hi Lars,
This fix does not appear until Hyades 3.3 (i1). The Hyades 3.2 does not
contain the fix. I will check to see if we can get this defect included in
3.2, assuming we have another cut of the release.
The workaround would be to create another plugin.xml using the PDE and
copy the content of the \plugins\org.apache.jakarta_log4j_logging_1.2.8
plugin.xml file.
Paul
news:cv4k8m$7av$1@www.eclipse.org...
> Paul,
from
Previous Topic:Attention EclipseCon attendees interested in TPTP
Next Topic:Hyades "extension points" summary wanted
Current Time: Sat Jul 26 18:32:40 EDT 2025
Powered by FUDForum. Page generated in 0.03796 seconds
