Re: Xtext Reader for unnamed Grammar Element [message #642194 is a reply to message #638868] |
Tue, 30 November 2010 10:50 |
Helge Mising name Messages: 17 Registered: October 2010 |
Junior Member |
I did a lot of debugging. I am sure that my name provider is never called. It seems that something is going wrong with registering it. That is, when I debug the RuntimeModule of my language, then the language provider class contains only 'null' and '0' elements. Especially, I would expect the 'qualifiedName' method to appear in the 'publicMethods'.
When debugging the URIBasedReader and particularly the corresponding SlotEntry class, I see that the
Quote: |
Could not find any exported element of type 'CompilationUnit' -> Slot 'j' is empty.
message is generated by the 'put(...)' method. There, the model class is correctly assigned to 'eClasses' (see code snippet) but the method 'findEObjectsOfType' returns an empty list since 'resourceDescriptions.getAllResourceDescriptions();' returns an empty collection.
public void put(WorkflowContext ctx, IResourceDescriptions resourceDescriptions, ResourceSet resourceSet) {
Set<EClass> eClasses = findEClasses(resourceSet, nsURI, type);
List<EObject> elements = findEObjectsOfType(eClasses, resourceDescriptions, resourceSet);
How do I get my name provider properly registered? Do I have to set anything else, like dependencies to certain plugins, particular switches when running the workflow,... ? May the problem be caused by my setup, since I think that something in the injection process goes wrong? I am using XText (1.0.1) on Java version 1.5.0_24 (32Bit) on Mac OS 10.5.8.
Best,
Helge
FUDForum. Page generated in 0.03658 seconds
