Home » Eclipse Projects » Remote Application Platform (RAP) » Using UICallback for all Server Operations
Using UICallback for all Server Operations [message #638198] |
Wed, 10 November 2010 12:20 |
David Ellis Messages: 15 Registered: September 2010 |
We are building a multi-user Eclipse RAP application, which will potentially have a large number of concurrent users.
Our architect would like all calls to the back-end database server to be made asynchronously, via message queues. When the user requests a function, such as "open record", rather than making a blocking call to the server, the application should send a message, and then an asynchronous message would come back containing the data to be displayed, and the record would open.
I have prototyped this using UICallback, and it appears to work OK. The callback is created when the menu operation is requested. The background thread sends the message to the server, and waits for the response message. It then notifies the UI to be updated via a Display.asyncExec() call.
This is based on the example at:
http://wiki.eclipse.org/RAP/FAQ#How_to_update_the_UI_from_a_ background_thread
So this appears to work., I just wonder if using UICallback in this way for all operations is good practice, or whether there are any pitfalls to this?
Thanks.
Re: Using UICallback for all Server Operations [message #638221 is a reply to message #638198] |
Wed, 10 November 2010 14:57 |
David,
You might want to look at using the Job api for this use case. You can start a job which will wait for the background task to complete and then return to the user. The advantage is that you do not have any dependencies on RAP so that if you want to run your application as an RCP client it should work just as well. Also you get progress for the user (although you can disable this if you don't want it). Most importantly, RAP handles creating and releasing the UICallback so you don't have to manage it manually.
That said, Jobs only work for user-initiated updates. If you need timely updates from background tasks or actions by other users, then you need another solution. You can open a session-long UICallback, which we do but is not recommended by the RAP team. Or you can setup the client to poll at a frequent interval. We have a custom widget which does this because it is not built into RAP.
Hope that helps,
Cole
Re: Using UICallback for all Server Operations [message #639275 is a reply to message #638198] |
Mon, 15 November 2010 20:48 |
Hi David,
we usually do not recommend to enable the UICallBack globally. Reasons
are:
* Some proxies might cut connections after a period of inactivity. This
would break the UICallBack mechanism.
* The standing request prevents session timeouts as long as the browser
is open.
* The number of open connections to be handled by the servlet container
increases.
If these aren't issues for you, then I guess a global UICallBack is fine.
HTH, Ralf
> call.
FAQ#How_to_update_the_UI_from_a_background_thread
> to this?
Ralf Sternberg
Need professional support for RAP and RCP?
http://www.eclipsesource.com/support/
Twitter: http://twitter.com/eclipsesource
Blog: http://www.eclipsesource.com/blogs/
Current Time: Sat May 04 18:46:23 GMT 2024
Powered by FUDForum. Page generated in 0.03874 seconds
