Home » Language IDEs » Java Development Tools (JDT) » [JDT_UI]Custom IMarkers visible in CompilationUnitEditor
[JDT_UI]Custom IMarkers visible in CompilationUnitEditor [message #64206] Sat, 21 June 2003 23:29 Go to next message
Given:
IMarker marker =
method.getCompilationUnit().
getCorrespondingResource().
createMarker(IMarker.PROBLEM);
marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_ERROR);
marker.setAttribute(IMarker.MESSAGE, message);
marker.setAttribute(IMarker.CHAR_START, start);
marker.setAttribute(IMarker.CHAR_END, length);
The markers I create show up in the Tasks view but not in the
compilation unit editor. I want them to show up as squiggly underlines
in the compilation unit editor as well, but have not discovered how to
make this happen. All the code that does this inside JDT appears to be
in internal packages; is there an external API that will let me do this?
Thanks in advance,
Dave
Re: [JDT_UI]Custom IMarkers visible in CompilationUnitEditor [message #65772 is a reply to message #64206] Tue, 24 June 2003 04:18 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
David J. Orme wrote:
> Given:
> IMarker marker =
> underlines in the compilation unit editor as well, but have not
> discovered how to make this happen. All the code that does this
> inside JDT appears to be in internal packages; is there an external
See org.eclipse.ui.texteditor.MarkerUtilities
For more info search (http://www.eclipse.org/search/search.cgi) the news
archive for similar questions. This has been answered many times.
HTH
Dani
Re: [JDT_UI]Custom IMarkers visible in CompilationUnitEditor [message #66544 is a reply to message #65772] Tue, 24 June 2003 23:42 Go to previous message
>> Given:
>> IMarker marker =
Ooooops. You're right; I should have STFN first.
Dave
Previous Topic:Mutliple Source Folders
Next Topic:Using eclipse with an existing (complex) project
Current Time: Sun Aug 31 02:20:16 EDT 2025
Powered by FUDForum. Page generated in 0.03288 seconds
