Home » Archived » BIRT » How do you use BIRT Scripting?
How do you use BIRT Scripting? [message #64172] Wed, 03 August 2005 16:17 Go to next message
If you are using BIRT scripting, I'd appreciate it if you could tell me
what you are doing with it and how you are using it. Additionally, what
would you like to be able to do with BIRT scripting and you currently can't?
Thanks in advance!
Krishna
Re: How do you use BIRT Scripting? [message #76449 is a reply to message #64172] Thu, 22 September 2005 10:55 Go to previous messageGo to next message
I would REALLY like to see
Context sensitive typing (intelli-sense)
For example of #2 if I'm scripting the beforeOpen event on the
DataSource Object, give me some way to see the objects available at this
scope as well as the methods etc.... so I can intuitively develop script
with out a lot of searching around in birt specs and documentation.
Krishna Venkatraman wrote:
> Hello,
> can't?
> Thanks in advance!
> Krishna
Re: How do you use BIRT Scripting? [message #76465 is a reply to message #64172] Thu, 22 September 2005 10:56 Go to previous message
> Hello,
> can't?
> Thanks in advance!
> Krishna
Previous Topic:About oracle date type!
Next Topic:Is there any way to remove table columns at runtime?
Current Time: Mon Jul 14 19:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.03541 seconds
