Home » Eclipse Projects » Mylyn » cannot upgrade to 3.0.3, eclipse 3.4
cannot upgrade to 3.0.3, eclipse 3.4 [message #64087] Fri, 09 January 2009 05:07 Go to next message
I have mylyn 3.0.2 installed, when I try to upgrade to 3.0.3, I get the
following error:
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.mylyn.jira.core/osgi.bundle/3.0.3.v20081015-1500 -e3x
org.eclipse.mylyn.jira.ui/osgi.bundle/3.0.3.v20081015-1500-e 3x
org.eclipse.mylyn.jira_feature/org.eclipse.update.feature/3. 0.3.v20081015-1500-e3x
Can anyone point me to any info that will help me resolve this?
I am using the Help -> Software Updates tool to perform the upgrade
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #64178 is a reply to message #64087] Tue, 13 January 2009 02:18 Go to previous messageGo to next message
I am getting a similar error. I have just performed a clean install of
Eclipse 3.4.1 Classic, I have added GEF-ALL-3.4.1, WTP-sdk-R-3.0.3 and
Mylyn-3.0.3-e3.4 without issue, but when I add mylyn-3.0.3-extras I get
the error below. I have checked the "Plugin Details" window and it says
that it the bundles shown below are already installed (exactly the same
version numbers).
Please note that all the plugins are being installed from local copies of
the files as these PCs do not have access to the internet to install
directly.
-- Error Message follows ---
No repository found containing: javax.xml/osgi.bundle/1.3.4.v200806030440
org.apache.xerces/osgi.bundle/2.9.0.v200805270400
org.apache.xml.resolver/osgi.bundle/1.2.0.v200806030312
org.apache.xml.serializer/osgi.bundle/2.7.1.v200806030322
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #64209 is a reply to message #64178] Tue, 13 January 2009 10:04 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
You may need a copy of Orbit somewhere as well. Not sure if they have
an update site for orbit or not though. The Xerces plugins comes from
orbit.
Dave
> version numbers).
> of the files as these PCs do not have access to the internet to install
> directly.
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #64229 is a reply to message #64209] Tue, 13 January 2009 20:27 Go to previous messageGo to next message
OK, I have resolved my issue. I have WTP installed (which installed the
bundles which the mylyn install was complaining about). I had installed
using downloaded files (I am unable to use the update site) and had copied
them into the "plugins" directory (apparently this sort of "unzip into the
eclipse directory" type of installation should now go into the "dropins"
directory). I re-installed Eclipse and when installing WTP I put it into
the "dropins" directory and then my installation of mylyn-extras worked
fine.
It appears as if Eclipse will find and use packages which have been copied
into the "plugins" directory but there is a bit of a glitch when using
them as pre-requisites for other plugins which are installed using the
update manager (either from the web, or using local "archive" files) where
the dependancy is recognised initially (prior to installation it seems to
think that the dependancies have been satisfied), but the later stages of
the install fail to see the dependancy and bomb out.
This may have been the cause of Gary's original issue (did you install the
earlier version of mylyn by copying into the "plugins" folder, or did you
use the update manager?)
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #64298 is a reply to message #64229] Wed, 14 January 2009 11:21 Go to previous message
I've always used the update site, mostly for updating plug-ins.
I have re-installed a fresh ganymede-sr1 and now, if I select the [Update]
from the Installed Software page, I have upgraded to 3.0.3 successfully.
no idea why this is different to my previous installation, but it's all
working now
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #595723 is a reply to message #64087] Tue, 13 January 2009 02:18 Go to previous message
version numbers).
directly.
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #595733 is a reply to message #64178] Tue, 13 January 2009 10:04 Go to previous message
orbit.
Dave
> version numbers).
> directly.
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #595740 is a reply to message #64209] Tue, 13 January 2009 20:27 Go to previous message
fine.
Re: cannot upgrade to 3.0.3, eclipse 3.4 [message #595766 is a reply to message #64229] Wed, 14 January 2009 11:21 Go to previous message
working now
Previous Topic:How to load/display attachments without URL
Next Topic:JIRA Connector does not work with JIRA Studio?
Current Time: Thu Jul 17 18:43:39 EDT 2025
Powered by FUDForum. Page generated in 0.05060 seconds
