Home » Eclipse Projects » Nebula » Matters about high CPU usage rate
Matters about high CPU usage rate [message #5727] Wed, 21 June 2006 01:58 Go to next message
Originally posted by: zmfeng.21cn.com
Dear all:
I've tried the snippets.Does anyone notice anything when you maximized
the shell and move the mouse over the area where there're data? Nearly 100%
cpu usage! will this be fixed in the next version??(I am running the test on
a Win2k3 with AMD Sepron2.4 and 512MRAM)
Re: Matters about high CPU usage rate [message #5745 is a reply to message #5727] Wed, 21 June 2006 09:56 Go to previous message
Which snippet? Is the shell locking up (i.e. some kind of loop)?
The Grid will do some not insignificant work during each mouse move
event to support mouse hover effects within cells and the header.
Though this code could probably be better optimized (redrawing only
certain areas) this has not been problematic.
Can you better explain what you're seeing?
-Chris
zmFeng wrote:
> Dear all:
Re: Matters about high CPU usage rate [message #562580 is a reply to message #5727] Wed, 21 June 2006 09:56 Go to previous message
-Chris
zmFeng wrote:
> Dear all:
Previous Topic:Matters about high CPU usage rate
Next Topic:Grid rows resizeable?
Current Time: Sun Aug 31 17:21:57 EDT 2025
Powered by FUDForum. Page generated in 0.04334 seconds
