Home » Eclipse Projects » JFace » How to get scolling in a wizard dialog
How to get scolling in a wizard dialog [message #491] Thu, 30 April 2009 18:33 Go to next message
Originally posted by: francis.oaklandsoftware.com
I have a wizard dialog which has worked great, but now I'm trying it on a
low-resolution 800x600 and the contents will not scroll. I can't find any
obvious ways to add scrolling support (maybe I'm doing something wrong in
populating the page, below is the code I use for that).
Out of curiosity, I tried the new Java project wizard and it has the same
problem, and if you are on 800x600 it's not possible to select a working
set because you can't make that fully visible.
(BTW - I need to use 800x600 for recording a screen cast, it's not cuz I
have a really old computer).
Looking for that snappy Boris response!
My code in the Wizard page:
public void createControl(Composite parent)
final Composite composite = new Composite(parent, SWT.NULL);
setControl(composite);
composite.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true,
true));
composite.setLayout(new GridLayout());
Label label;
label = new Label(composite, SWT.WRAP);
label.setText(GuiMessages.JavaImporterPropsPage_Select);
label.setLayoutData(new GridData(SWT.BEGINNING,
SWT.BEGINNING,
false,
false));
.... much more ....
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: How to get scolling in a wizard dialog [message #508 is a reply to message #491] Fri, 01 May 2009 01:10 Go to previous messageGo to next message
Hi Francis,
"Francis Upton" <francis@oaklandsoftware.com> wrote in message
news:op.us70xcdqmbraco@berlioz...
Sounds like a question for the SWT newsgroup to me...
Have a look at the preferences dialog, I think it does implement scrolling.
Kim was swearing a lot while she worked on it, so I would expect the worst
hehe!
> ... *SWT* code...
See? You are a little off topic ;-)
Boris
Re: How to get scolling in a wizard dialog [message #521 is a reply to message #508] Fri, 01 May 2009 02:47 Go to previous messageGo to next message
*shudder* I suspected I would have to get involved with my good friend
the ScrolledComposite. I understand why she was swearing. Thanks for the
pointer!
On Thu, 30 Apr 2009 22:10:25 -0700, Boris Bokowski
<Boris_Bokowski@ca.ibm.com> wrote:
> Hi Francis,
>> a
>> any
>> in
>> same
> scrolling.
> worst
> hehe!
>> ... *SWT* code...
> Boris
Re: How to get scolling in a wizard dialog [message #534 is a reply to message #521] Fri, 01 May 2009 09:24 Go to previous messageGo to next message
Btw, the bug for the general problem (WizardDialog should scroll like
preferences dialog) is: https://bugs.eclipse.org/bugs/show_bug.cgi?id=188724
Boris
news:op.us8ntxc3mbraco@berlioz...
> pointer!
>> Hi Francis,
>>> a
>>> any
>>> in
>>> same
>> scrolling.
>> worst
>> hehe!
>>> ... *SWT* code...
>> Boris
Re: How to get scolling in a wizard dialog [message #548 is a reply to message #534] Fri, 01 May 2009 09:57 Go to previous messageGo to next message
Hmmm, well since I need to do the work anyways, might as well put it in
the correct place.
On Fri, 01 May 2009 06:24:50 -0700, Boris Bokowski
> Boris
>> the
>> pointer!
>>> Hi Francis,
>>>> on
>>>> a
>>>> any
>>>> in
>>>> same
>>>> working
>>> scrolling.
>>> worst
>>> hehe!
>>>> ... *SWT* code...
>>> Boris
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788241] Wed, 30 May 2018 12:25 Go to previous messageGo to next message
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788267] Wed, 30 May 2018 12:31 Go to previous message
Previous Topic:Pack tree columns on property sheet entry change
Next Topic:Where to get Jface source code including compile information
Current Time: Sat Jul 26 09:07:07 EDT 2025
Powered by FUDForum. Page generated in 0.29433 seconds
